steering box / loose steering
Old Sep 17, 2018 | 08:38 PM
viperman86's Avatar
viperman86
hey guys, I had some "slop" in the steering wheel, so today I adjusted the nut/screw on the steering box. I had to adjust it 1 & 3/4 . Wanted to know if that was too much ? Steering is still not the best but I would say 50-70% better. Soon I will also check the alignment.
Old Sep 17, 2018 | 08:43 PM
pirate4x4_camo's Avatar
pirate4x4_camo
1.75 turns me thinks you will be buying a new gear soon enough, in the mean time I would bet money the play is now coming from the rod ends, loose pitman arm and even the track bar bushings
Old Sep 17, 2018 | 09:02 PM
viperman86's Avatar
viperman86
uhhh ohhzz
Old Sep 17, 2018 | 09:28 PM
Colorado350's Avatar
Colorado350
I agree with Pirate but as long as the bolt isn’t tightened down all the way you have some life left in the box. Time to look at other parts being worn too
Old Sep 17, 2018 | 09:37 PM
viperman86's Avatar
viperman86
first turn was not quite 3/4, then 1/2 and 1/2, so it's more like 1.5-1.75 ...I did some full U-turns and truck steering seemed fine, did not lock up. steering wheel feels firmer for sure. so what major components would make it feel like it's "floating" ?
Old Sep 17, 2018 | 10:14 PM
Colorado350
TRE’s, draglink assembly (where TRE & DLA meet) and draglink socket assembly (where connects to pitman arm) I would also check your ball joints. Once those are dealt with you can add a stab to take up any slack but AFTER those consumables are fixed.
Old Sep 18, 2018 | 03:51 PM
Brother Les's Avatar
Brother Les
Waay to much on the steering nut screw... take it back to where you started. 1/8 of a turn at a time. With as far as you went.... the steering is not 'better'.... you are just binding up the gear. Look elsewhere for the 'slop'.
Old Sep 18, 2018 | 04:40 PM
hydro man 17's Avatar
hydro man 17
I agree with Les. There is a "crush washer" associated with that adjusting nut that is REALLY easy to crush. Once done the box is essentially done as well. I guess that I bought my Redhead before they started having (reported) problems because mine is fine. I hear that there are a couple of "new(er) kids" on the block so you might give them a look as well.
Old Sep 18, 2018 | 04:51 PM
viperman86's Avatar
viperman86
yep, going to check out the suspension ...prolly order all new inner/outer tie rods
Old Sep 20, 2018 | 05:36 PM
viperman86's Avatar
viperman86
ok my buddy/diesel mechanic drove it ....he says I'm used to my 2015 F150 "tight" steering LOL. He said there is a little play but not too bad, with a little bump steer. He said the best thing to do is add a dual steering stabilizer.
Old Sep 20, 2018 | 07:58 PM
pirate4x4_camo
Steering dampener does not fix or mask bump steer
bump steer is caused by the drag link and the track bar not being on the same angle and when the suspension cycles they each move in a diffrent arc and forces the drag link to physically turn the wheels to match the diffrence in dinstace traveled.
The only way to solve that is to get the arc to match by using a dropped pitman arm and or a dropped track bar bracket.
Old Sep 20, 2018 | 08:00 PM
pirate4x4_camo
The best thing to do is find the worn out parts and replace them not put a bandaid on it.
Old Sep 21, 2018 | 10:45 AM
brian42's Avatar
brian42
Veteran: Navy
What pirate4x4_camo said. I would find the loose steering components first.
If your avatar is your truck your tires look pretty close to stock size. I wouldn't consider adding another stabilizer IMO.
Old Sep 21, 2018 | 12:26 PM
viperman86's Avatar
viperman86
gonna have les schwab check it out soon
Old Sep 23, 2018 | 11:49 AM
'88 E-350's Avatar
'88 E-350
Bump steer shouldn't be happening if the pitman arm or track bar haven't been modified, usually done to compensate for a lift. If it has bump steer with stock components something's loose/worn.
Over tightening the box adjustment can damage it. It can also cause excessive drag which can make the vehicle not self-center well and feel like it's wandering/floating. I've had two wanderers and in both cases someone had messed with the screw. Loosening it a little helped a little, but once they've been overtightened I think there's damage done that can't be fixed without a teardown. The adjustments are pretty critical.
Feb 23, 2018 01:12 PM
Matt In Detroit
1978 - 1996 Big Bronco
25
Feb 19, 2011 07:51 AM
afonda
18
Feb 28, 2009 07:51 AM
13MWZ
Nov 24, 2007 05:38 PM
brider
May 24, 2005 04:54 PM
