What trans do i have
Old May 17, 2009 | 03:29 PM
stroked88ranger's Avatar
stroked88ranger
Hey all, im stumped, today is the first day I could look under my truck that i bought when i was in iraq. Im trying to find out the trans in it. The door sticker says the trans code is "Z" damn internet isnt giving me crap for info. Here is a few pictures, can anyone of u guys tell me what you think this is? I dont know if it is an M50D or not. Im confoozled.
One pic...
and the other...
Old May 17, 2009 | 06:44 PM
85e150's Avatar
85e150
The cover, aluminum case and integral bell look something like the ZF in the pics here:
Domestic Truck Tranny Guide
But I can't match it 100%.
Is this in the "stroked88ranger"?
If it's a stock Ranger, it's a Mazda box, unless you got really unlucky with an early one and a Mistubishi (IIRC) trans.
If it's an F-series, and first is low, it's a ZF.
So, what truck, year engine etc?
I could not find the 'Z' code here:
https://www.ford-trucks.com/article/...r_Decoder.html
Old May 17, 2009 | 06:46 PM
krvoorheis's Avatar
krvoorheis
There should be a tag on the case somewhere. Get the number from the tag, call a ford dealer, ask for the parts department. Tell them you want to know what trans you have and give them the number. They will be glad to look it up. If there is no trans tag and the unit is original to the vehicle, give them the VIN # instead.
Old May 17, 2009 | 07:16 PM
stroked88ranger
this is my door tag... its my f-250. i dont understand why there is no z code. i know its a 5 spd intrical bell housing, i just want to know what it is exactly and is it strong.
hope this helps anyone. also proof that im not crazy. lol
Old May 17, 2009 | 07:27 PM
johnboy427's Avatar
johnboy427
Its a ZF the Mazda units didn't have PTO covers. Is this truck an F250/350 with at 4.9/5.0/5.8? It could also be ordred in a F150 but this was rare, but many people do the swap because the M5 is easy to break and has too high of a 1st gear if you pull anything.
-Johnboy
Old May 17, 2009 | 09:25 PM
stroked88ranger
Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! It IS the ZF, that looks exactly like whats under my truck. It has the 5.8 You are the MAN! I was looking all day and couldnt find anything about the dang thing. Thanks bro.
Old May 17, 2009 | 09:39 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Interesting puzzle!
I do not know what it is, But it's not a ZF5...
If it was a ZF5 it will have an ID plate just above the drivers side PTO delete cover, or at least a place for the plate...
The ZF5 also has cross hatch ribs above the PTO delete cover surrounding the ID plate.
The area forward of the PTO delete cover is not correct for the ZF5.
The ZF5 is a Hydraulic Clutch transmission. (I can't see one, pic is dark for me though)
The fill plug area is not correct for a ZF5
-Enjoy
fh : )_~
Old May 17, 2009 | 09:41 PM
Festus Hagen
Methanoholic
Did you find something on it that says it's a ZF??
-Enjoy
fh : )_~
Old May 17, 2009 | 09:48 PM
johnboy427's Avatar
johnboy427
The slave cylinder is internal you can see the line going into the bellhousing in the top picture that is how I knew it wasn't for a 460 or a diesel.
-Johnboy
Old May 17, 2009 | 10:10 PM
Festus Hagen
Methanoholic
I have to admit it does resemble a ZF, but everything I can find shows nothing like that... Then again I cannot find a good pic of one with an internal slave.
And everything I have shows subtle differences that just don't fit...
But I am human and I could very well be wrong! Been so many times, and I'm sure I'll be many times again! ...
I would be interested in seeing the numbers on the ID plate!
-Enjoy
fh : )_~
Old May 17, 2009 | 10:21 PM
johnboy427's Avatar
johnboy427
Pretty sure its is a ZF most just look a little different because of the clutch fork opening but the the PTO plates exactally opposite each other and if you look closely at the second pic you can barely see the ID plate right above the PTO cover where it should be. Yeah it sure would help to know what kinda truck it is too.
-Johnboy
Old May 17, 2009 | 10:47 PM
Festus Hagen
Methanoholic
Yea, I'm really curious now ... The pics are to dark for me to see much above the PTO delete covers.
I have not seen a ZF with internal slave, so that could be where my confusion is.
Hopefully the OP gets a chance to look for the plate and confirms for us...
For the OP's sake, I hope you are correct and I am wrong, the ZF is a good trans.
-Enjoy
fh : )_~
Old May 18, 2009 | 12:06 AM
stroked88ranger
I pried that sucker off and its a ZF s 5-42. I thought it was stuck on there, till i realized it was held on with rivets. I popped it off and cleaned it off and typed it in google. and sure enough, i found a trans that looks better comparison than the zf 5. I was stumped cuz i thought there was going to be a tag on a bolt somewhere on the trans, which there was not. Hunting is over. Thanks guys.
Old May 18, 2009 | 12:40 AM
stroked88ranger
Here is the tag i pried off and cleaned up...
Old May 18, 2009 | 02:23 AM
Festus Hagen
Methanoholic
Cool, The ZF is a good trans.
Learn something new everyday ...
I hope you plan on putting the tag back on.
-Enjoy
fh : )_~
