Water pump and fan clutch
I installed the exact same setup on mine and have been towing with it down here in Texas where it gets pretty hot and also pretty cold in winter and have zero complaints about it’s performance. I have over 10,000 miles on it and coolant/oil stays around 198 in winter and 200-205 in summer maybe 210 towing my tractor when it’s over 100 degrees outside. I have no issues running too cool, if your ECT is below 190 you have a thermostat issue.
I just replaced my fan clutch a few hundred miles ago and somehow the wires got caught in the fan. Water pump was my first thought because this was how I caught my water pump going bad a few hundred miles ago. Water pump is good so I need a new fan clutch. Running without right now (Pretty cold and have no temp issues) but need to get it fixed. @MisterCMK are you still happy with the upgrade?
Thanks
Jim
Thanks
Jim
Sparky83
01-13-2019 02:13 PM
tomwhatley
08-22-2014 09:44 AM
old blue 90
09-25-2007 08:33 AM
