PCM Compatibility
Old Sep 13, 2018 | 09:17 PM
565edge's Avatar
565edge
PCM Compatibility
I have a Wwv1 Dc-432 PM in my truck. Does anyone know if I can remove it and install a pmt-1 PCM?
Old Sep 13, 2018 | 09:46 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yes. No problems. Why do you want to change though?
Old Sep 13, 2018 | 10:25 PM
565edge's Avatar
565edge
I have tunes from G.H. and they run decent. I bought tunes from another company and having issues getting them right. The new files idle rough and seems to run rough coming back to idle. I'm on the 3rd set of tunes and each set run differently. He is helping me out but it seems like people have issues getting this pcm correct. I do not feel my truck runs/tows as well as it should. I have 238/80 injectors with a 366sxe t4 that I just mounted.
Old Sep 13, 2018 | 10:27 PM
565edge's Avatar
565edge
I tow a Gearbox 375s toyhauler. Some say its 38' and some say 39'. It weighs around 17k. Truck is a 2000 f350 dually with an auto, 4.10's and 295 tires.
Old Sep 13, 2018 | 10:30 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Makes sense.
Yep, you're good to go. The DPC-432 is a 50-state PCM for use with a glow plug relay and the subsequent individual bank monitoring of glow plug command. Luckily, the pinout on the harness and PCM is the same but the DPC-422 won't even care about the extra inputs since the current-monitoring PCM pins aren't monitored.
As you're already aware, that's WAY too much trailer for that pickup anyway......but you gotta do what you gotta do.
Old Sep 13, 2018 | 10:33 PM
565edge's Avatar
565edge
Do you think a dpc-422 will work better? Or something different?
Old Sep 13, 2018 | 10:50 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
"Work better"? No. It "works" the same. However, everyone seems to tune for VRAA6S3 (PMT1) so the aftermarket supports it better. Truthfully, you don't even have to change the PCM. PMT1 tuning works just fine on a FHP/WWV PCM.
Old Sep 13, 2018 | 11:02 PM
565edge's Avatar
565edge
That is the tuning I ran from php with my stock injectors and what I think gearhead ran on my stock injectors. When I installed the 238's gearhead sent me new tunes. Which I also believe are for that same code you mentioned.
Old Sep 13, 2018 | 11:04 PM
565edge's Avatar
565edge
I have one tune that after half throttle it will not accelerate for about 10 seconds then takes off.
Old Sep 13, 2018 | 11:15 PM
565edge's Avatar
565edge
https://youtu.be/NuwIbzLp_6k
jlo84truck
Nov 30, 2016 07:14 PM
andy's2000
Jul 15, 2015 01:54 PM
DPDISXR4Ti
Mar 21, 2013 01:33 PM
95schauf
Mar 2, 2013 09:39 AM
rangerbob406
Oct 30, 2007 03:33 PM
