Can anybody identify this oil leak? -oil pooling on top of timing cover
I've seen that before. It looks like your intake gasket, specifically the cork piece over the front China rail. You can clean up the engine above where the puddle is, and then keep an eye on it to see if you can determine its path, but I think it's going to be the intake manifold gasket.
Many folks simply run a bead of RTV silicone, and skip the cork gaskets or end-gaskets.
Another alternative is an intake gasket set for a late '90s 5.0 explorer. The end gaskets on these are a molded deal which sort of 'clips' over the China rail. Not sure of the material, but they're blue. That gasket set is expensive though, and comes with a bunch of other EFI-only gaskets, so I would recommend going to the junkyard and just getting some used ones. It's a lot of digging to get to them out, but you should find them to be eminently reusable.
When I pulled a set of GT40P heads at the JY for my Mustang, I took those 15-year-old, surely >100,000 mile, end-gaskets/seals, and used them on my engine (of course with new manifold-to-head gaskets). They've been on there for over four years now with no leakage, so I recommend them.
That Explorer 5.0 engine was the pinnacle of the small block Fords in many ways.
Oh. PCV pulls plenty hard, but it has a lot of blow by mist coming out of breather. Maybe there's no point in replacing seals then?
Ok, then work on the crankcase pressure issue. It may be fixable. My favorite setup is breather filter on one valve cover ( that one should be sucking air IN), and a hose from the other valve cover to the full time vacuum port at base of the carb, or intake manifold.
kr98664
05-06-2019 11:27 PM
big hoss 29
12-29-2004 04:15 PM
RobSt
04-11-2003 06:39 AM
tim_1911
04-02-2002 12:47 PM
