Can anybody identify this oil leak? -oil pooling on top of timing cover
Old 09-13-2018, 07:19 AM
jackietreehorn's Avatar
jackietreehorn
jackietreehorn is offline
As shown in pics, oil pools on top of timing cover, I’ve washed it several times and it always returns after a while.
Old 09-13-2018, 08:36 AM
ranger140892's Avatar
ranger140892
ranger140892 is offline
I don't see a pic
Old 09-13-2018, 08:42 AM
jackietreehorn
Agh, the forum doesn't like mobile uploads...
Looking wet from passenger side down (#1 spark plug)
See pool below distributor on top of timing cover.
See large pool of oil looking down on top of timing cover (under water outlet)
Old 09-13-2018, 08:50 AM
EQCMCAT's Avatar
EQCMCAT
EQCMCAT is offline
Suspect it might be the O Ring on your distributor shaft and perhaps (including) your right bank (driver's side) head gasket. My 351M leaked oil around the distributor shaft like the picture you've shown until I replaced the O Ring.
Old 09-13-2018, 08:54 AM
meangreen92's Avatar
meangreen92
meangreen92 is offline
I've seen that before. It looks like your intake gasket, specifically the cork piece over the front China rail. You can clean up the engine above where the puddle is, and then keep an eye on it to see if you can determine its path, but I think it's going to be the intake manifold gasket.
Many folks simply run a bead of RTV silicone, and skip the cork gaskets or end-gaskets.
Another alternative is an intake gasket set for a late '90s 5.0 explorer. The end gaskets on these are a molded deal which sort of 'clips' over the China rail. Not sure of the material, but they're blue. That gasket set is expensive though, and comes with a bunch of other EFI-only gaskets, so I would recommend going to the junkyard and just getting some used ones. It's a lot of digging to get to them out, but you should find them to be eminently reusable.
When I pulled a set of GT40P heads at the JY for my Mustang, I took those 15-year-old, surely >100,000 mile, end-gaskets/seals, and used them on my engine (of course with new manifold-to-head gaskets). They've been on there for over four years now with no leakage, so I recommend them.
That Explorer 5.0 engine was the pinnacle of the small block Fords in many ways.
Old 09-13-2018, 08:55 AM
jackietreehorn
I replaced the distributor a couple moths back and the leak hasn't changed. I believe it came with a paper gasket and O-ring. I didn't know head gaskets leaked oil outside the block?
Old 09-13-2018, 09:02 AM
EQCMCAT's Avatar
EQCMCAT
EQCMCAT is offline
Don't recall a paper gasket for the distributor. I've had head gasket leaks outside the block but they've been on my assortment of Ford Rangers over the years W/the 2.3 L 4 cyl. Think Meangreen92 advisement is more in tune to the amount of oil shown in your pictures.
Old 09-13-2018, 09:14 AM
ranger140892
Hard to tell in those pics but I'm thinking leak from front of the intake manifold. If that's it, first I'd check for crank case pressure. Or it could just be an old seal (whether gasket or RTV).
Old 09-13-2018, 09:17 AM
jackietreehorn
Ok, must the intake manifold gaskets be replaced if the manifold removed to apply silicone along the china ridge?
If so, I might as well by the explorer gasket kit.
Old 09-13-2018, 09:25 AM
ranger140892
Yes, if it's leaking, replace it. But make sure you're finding the cause. If it's crank case pressure, you'll have another leak. And the next one could be at the rear main, and or damper seal. Look at your PCV setup.
Old 09-13-2018, 09:33 AM
jackietreehorn
Oh. PCV pulls plenty hard, but it has a lot of blow by mist coming out of breather. Maybe there's no point in replacing seals then?
Old 09-13-2018, 09:43 AM
ranger140892
Ok, then work on the crankcase pressure issue. It may be fixable. My favorite setup is breather filter on one valve cover ( that one should be sucking air IN), and a hose from the other valve cover to the full time vacuum port at base of the carb, or intake manifold.
Old 09-13-2018, 09:46 AM
jackietreehorn
That's what I got. Must be the rings.
Old 09-13-2018, 11:23 AM
TheMonson's Avatar
TheMonson
TheMonson is offline
My FE had a big leak on the front of the intake manifold, made a mess out of everything. Wish I knew about the Explorer china wall gaskets a couple weeks ago for my 92 I'm about to head swap :/.
kr98664
05-06-2019 11:27 PM
bass-n-fire
1997 - 2003 F150
03-24-2017 11:50 PM
big hoss 29
12-29-2004 04:15 PM
RobSt
04-11-2003 06:39 AM
tim_1911
04-02-2002 12:47 PM
Quick Reply: Can anybody identify this oil leak? -oil pooling on top of timing cover
