EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
5W- 20 VS 5W-30 WT OIL
Old 09-11-2018, 11:36 PM
billy boby's Avatar
billy boby
billy boby is offline
I LIVE IN SOUTHERN CALIFornia where its hot most of the time ,just wondering would it be ok to run a 5w-30wt oil rather than 5w-20 wt ? i read it 5w-30 should only be used in the 3.7 V6 I have a 2008 4.2 V6 EB With 62K
Old 09-12-2018, 12:54 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Your engine could use either really, but knowing a 5w20 has a higher HT/HS and most 5w30 oils shear to 5w20 what's the point? The 3.7 engine didn't exist in your year of truck and for reference your 4.2 is not a EB.
Old 09-12-2018, 04:45 AM
billy boby's Avatar
billy boby
ok its not eco boost ?
Old 09-12-2018, 05:12 AM
glockholiday's Avatar
glockholiday
glockholiday is offline
Just run whatever the manual says.
Old 09-12-2018, 05:59 PM
dkf's Avatar
dkf
dkf is offline
Yes you can run 5w30 without problem. Only reason Ford even went to 5w20 in many of the engines was to try and squeeze a tiny bit of mpg out. You are doing no favors to the engine running 5w20 over a 5w30. Ford actually has been transitioning many engines back to 5w30.
Old 09-12-2018, 07:59 PM
ford390gashog
Do you see turbos? The EcoBoost started in 2011 model year F150 trucks.
Old 09-12-2018, 08:40 PM
billy boby's Avatar
billy boby
ok thank you im just learning , to change the subject ,i did own a 390, and it was a great motor , just ate the gas , drove it to Alaska and i always luved that truck 1976 F250
Old 09-14-2018, 09:26 PM
onug's Avatar
onug
onug is offline
Dude...first, welcome the forum. But honestly, if you don’t know if your motor has turbos or not, you’re way ahead of yourself in asking about oil. Stick with what For recommends and you’ll be fine.
Wrenchgear
2009 - 2014 F150
54
06-30-2021 03:51 PM
dwestove4
1997 - 2003 F150
05-26-2005 11:58 PM
Brother65
Oil & Lubrication
09-17-2004 09:20 AM
gtm245
Oil & Lubrication
03-07-2004 03:39 PM
mefsh
Oil & Lubrication
12-19-2000 06:47 PM
Quick Reply: 5W- 20 VS 5W-30 WT OIL
