Stumped by starter relay
Old Sep 9, 2018 | 01:30 PM
nickniles's Avatar
nickniles
So when I try to start my 99 f250 triton the relay won't even click. So I crossed it over on the relay and it starts fine. Figured the relay was bad. Changed it, same issue. Any ideas?
Old Sep 9, 2018 | 02:05 PM
projectSHO89's Avatar
projectSHO89
Did you first check to see if the relay was getting its signal (small wire) to turn on when the key is in START?
Which specific terminals did you "cross over"?
Manual or automatic transmission? If auto, did you also try in "N"?
Any exhaust or transmission work done recently?
Old Sep 9, 2018 | 04:13 PM
nickniles's Avatar
nickniles
How would I go about checking that? Voltage meter?
the little one with the push-on connector and the bottom bolt(the bolt that the battery and alternator run to)
it's auto, I have not tried in neutral, but i will in just a minute. Didn't even think of that. Im not a mechanic by no means, but know how to do some stuff. Also, too broke to pay somebody lol.
thanks
Old Sep 9, 2018 | 04:14 PM
nickniles's Avatar
nickniles
And no exhaust or transmission work.
Old Sep 9, 2018 | 04:33 PM
nickniles's Avatar
nickniles
Won't start in neutral either.
Old Sep 9, 2018 | 06:46 PM
Franklin2's Avatar
Franklin2
You have a dedicated fuse for start. It's fuse 21, 15 amp in the underdash fuse box. Make sure this fuse is good. If the fuse is good, what I would do next is get a voltmeter or testlight, hook one side to ground and take the probe and probe this fuse while someone else holds the keyswitch over to start. You should have voltage on the fuse when someone springs the key over to start. If you do, the problem is going to be downstream. If you do not have voltage on this fuse, the problem will be upstream, something to do with the ignition switch.
Downstream from the fuse the wire goes to side of the transmission, to the digital transmission range sensor or DTR sensor. This is basically a switch that completes the circuit when in park or neutral. Going into the switch the circuit is a darkblue/orange wire, leaving the switch is a tan/red wire which goes up to the starter relay you replaced.
Old Sep 9, 2018 | 08:56 PM
nickniles's Avatar
nickniles
Fuse is good. I'll check the rest tomorrow. Thanks for your advice. Also, since I bought this truck in July, I had a whole new a/c kit put in(mechanic shop. . Way beyond my abilities lol), new ignition switch, new pcm relay, new starter, starter relay, and replaced the battery cables to starter and relay.
Old Sep 10, 2018 | 10:06 AM
alloro's Avatar
alloro
Reach over with your left hand and hold the key in the start position as you use your right hand to pull the shift level down through all the positions. If doing this causes the starter to engage at any point let us know and we'll go from there.
Old Sep 10, 2018 | 11:54 AM
nickniles's Avatar
nickniles
did not engage.
Old Sep 10, 2018 | 12:54 PM
nickniles's Avatar
nickniles
There's no power at the fuse. Any suggestions?
Old Sep 10, 2018 | 03:03 PM
projectSHO89
Check for power at fuse F20, not F21, with the key in the START mosition. The above post gives the wrong fuse #.
Old Sep 10, 2018 | 03:07 PM
nickniles's Avatar
nickniles
according to my book, fuse 20 is a 5amp that runs audio, GEM module, and PCM. I'll check it, but you sure?
Old Sep 10, 2018 | 03:10 PM
projectSHO89
I'm looking at the factory service manual (EVTM) for the 99 F250 gasoline engine, cell 20-001. I have no idea what you're looking at.
Old Sep 10, 2018 | 03:17 PM
nickniles's Avatar
nickniles
I tested it anyways, no power.
Old Sep 10, 2018 | 03:18 PM
nickniles's Avatar
nickniles
also, by no means am I arguing because I'm no pro, just telling you what it says. I appreciate any help.
