lifter noise
Old Sep 8, 2018 | 10:49 PM
derbydad276's Avatar
derbydad276
lifter noise
can lifter bleed off once your off Idle ?
engine is quiet at idle but develops a lifter tick at cruise rpm
new cam ... lifters ... rockers ...springs ...
all Comp cam
pulls like a freight train
400 .030 over Tmeyer pistons
252 H compcam kit
heads shaved .010 when rebuilt to clean up
standard head gasket from rebuild kit I didnt write down thickness
any ideas??????????????????
Old Sep 9, 2018 | 03:29 AM
KULTULZ's Avatar
KULTULZ
The 351C/400 had oil supply/valve guide problems problems @ intro.
Did it do this before the cam upgrade? I would contact COMP CAM TECH LINE first and research CLV engine oiling mods in the meantime..
Old Sep 9, 2018 | 10:14 AM
beartracks's Avatar
beartracks
The oiling mods aren't really needed unless you spin high revs.
Old Sep 17, 2018 | 12:13 PM
mark a.'s Avatar
mark a.
Did you check lifter preload ? Aftermarket cams can be ground on a different base circle than the old stock cam so you should check push rod length as well. Milling heads and block will effect push rod length and preload too.
Old Sep 20, 2018 | 07:50 PM
baddad457's Avatar
baddad457
I would pull that valve cover and locate the noise source then check the preload on that lifter. if it's loose, it could be a cam lobe going bad..
dimora
176
Apr 26, 2018 08:00 PM
POPAJON
Sep 4, 2011 08:41 PM
slstreit
Feb 28, 2008 01:32 PM
65'f1004x4conver
57
Dec 7, 2006 03:05 PM
Zaratul
Sep 12, 2003 12:52 AM
