Countershaft stuck!!!NP435
Old Sep 7, 2018 | 12:10 PM
MATTSTEP's Avatar
MATTSTEP
Hello all, I’m a new member here, asking all NP435 guys. My countershaft in my NP435 Ford F-100 will not spin when I put the new thrust washer on the front and fit the tabs to the grooves on the actual transmission, what’s going on? Is the washer to thick? If I completely assemble it without the thrust washer it spins freely, but if the thrust washer is put in place and I tighten it back together nothing it seizes, any ideas would be great!
Old Sep 8, 2018 | 02:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by MATTSTEP
Hello all, I’m a new member here, asking all NP435 guys. My counter shaft in my NP435 Ford F-100 will not spin when I put the new thrust washer on the front and fit the tabs to the grooves on the actual transmission, what’s going on? Is the washer to thick? If I completely assemble it without the thrust washer it spins freely, but if the thrust washer is put in place and I tighten it back together nothing it seizes, any ideas would be great!
NP435 pic: Where is the counter shaft? No see um...because there isn't one. You sure your trans is a NP435 and not a Warner T-18?
Old Sep 8, 2018 | 11:30 PM
MATTSTEP's Avatar
MATTSTEP
It is the thrust washer labeled 7119 at the lowest cluster on the left side of the schematic of the transmission, I know for a fact that it is an NP435. But everything seizes once i get it all tightened down. But if I leave the 7119 thrust washer out, it spins freely all tightened down
Old Sep 9, 2018 | 04:40 PM
dlburch's Avatar
dlburch
Not sure if it helps, but here is a link to the relevant section of the service manual...
http://www.fordification.com/tech/PDF/NP435-rebuild.pdf
Old Sep 9, 2018 | 07:43 PM
NumberDummy
7119 is the cluster gear thrust washer.
The front is C4TZ-7119-A ~ 2 3/4" O.D. x 1 29/32" I.D. x 5/8" thick. GREEN SALES CO. in Cincinnati OH has 176 = 800-543-4959.
The rear is C4TZ-7119-B ~ 1 7/8" O.D. x 1 1/4" I.D. x 1/32" thick. GREEN SALES has 37.
ZCarr
Sep 4, 2018 04:48 PM
Robin13
Aug 12, 2015 12:09 AM
6978sghfbjklgdfsjhkl
Feb 11, 2015 06:00 PM
john fin
Oct 31, 2007 07:34 PM
