Sponsored by: Real Truck
E450 V10 oil
Old Sep 6, 2018 | 10:11 AM
barthboy2's Avatar
barthboy2
6th Gear
E450 V10 oil
i have a 2000 ford E450 6.8L gas burner under a 24' rv. i have always used 5-30w oil and changed every 3-4 thousand miles. the rig has 120,000 miles on it and is using some oil these days. my recent 4,000 mile trip it used 1.5-2.0 quarts. question is could i safely change to 10-30w. thanks barthboy2
Old Sep 6, 2018 | 11:04 AM
Djosbun's Avatar
Djosbun
Never change to a different oil viscosity due to the engine burning/using oil. The internal tolerances were engineered for a specific weight oil. And correct me if I am wrong but doesn’t the V10 specify 5w-20?
— Dave
Old Sep 6, 2018 | 12:09 PM
Mike189677's Avatar
Mike189677
The older ones were 5w30 then they changed it around 02 to 5w20. Sort of unrelated but the 6.2 was ogrinally speced for 5w20 then they changed it to 5w30 after a few years.
Old Sep 6, 2018 | 12:47 PM
Batman7777's Avatar
Batman7777
I know specifically, some will go to a higher weight oil to buy some time.
This was to gain some time (amount of time depends) before a new motor is installed.
What's sad is this motor with only 120,000 miles should not be going out this soon. Almost, Infant Mortality..
Old Sep 6, 2018 | 01:46 PM
redford's Avatar
redford
FTE Leadership Emeritus
I agree, at 120k miles a V10 should not be using much if any oil.
Have you done any troubleshooting to pinpoint the cause of the oil loss?
Old Sep 6, 2018 | 03:52 PM
barthboy2's Avatar
barthboy2
6th Gear
yes i have check all the things i could think of. no oil leaking of course and the tail pipe is clean. changed plugs at 100K and the gap was wide but the plugs were clean and looked good.
Old Sep 6, 2018 | 04:02 PM
ford390gashog's Avatar
ford390gashog
Has the PCV been replaced? It's a common cause of sudden oil loss in a modular engine. I wouldn't change from the 5w30 if it's made it this far. Also all 6.8 engines are currently specified to run 5w20 and have been since 2001 MY, 5w20 is even used in the F650/750 Trucks.
Shorty Thompson
Nov 23, 2017 09:11 PM
rustyfuryiii
Modular V10 (6.8l)
30
Nov 24, 2006 04:49 PM
sharkwhit
Modular V10 (6.8l)
18
Oct 11, 2004 09:36 AM
W.B. Kelso
Modular V10 (6.8l)
Oct 6, 2004 08:37 PM
Edmo
Modular V10 (6.8l)
Jul 6, 2003 12:51 AM
