2019 Shark Fin
Old Sep 5, 2018 | 03:53 PM
GMoney1121's Avatar
GMoney1121
2019 Shark Fin
I see that the 2019s have that new shark fin antennae on the roof that sticks up. Does anybody know how high that sticks up, how much taller it is than the previous version, and if it can be replaced with the previous version? I test fit my garage with a 2018 and it cleared by about an inch, but now I’m worried that shark fin is going to stick up too high and a stupid antenna is going to prevent me from getting in the garage.
Old Sep 5, 2018 | 04:42 PM
crewzer's Avatar
crewzer
The new shark fin houses the GPS-, Sirius XM-, and 4G LTE modem antennae. It’s just under 2-1/2” tall.
HTH,
Jim/ crewzer
Old Sep 5, 2018 | 05:17 PM
pgordon888's Avatar
pgordon888
On a stock truck (I.e. factory rake) the highest point of the truck is still the back of the cab by the brake light. It's only if you level your truck that the shark fin becomes the highest point of the cab. At least that is what happened to me on a reverse level.
Old Sep 5, 2018 | 05:56 PM
GMoney1121's Avatar
GMoney1121
Thats good news. After all the research and everything I did to make sure it would fit, to have a stupid new antenna be the thing gets in the way would just p*** me off to no end.
Old Sep 14, 2018 | 01:14 AM
Tx.Hoon's Avatar
Tx.Hoon
I should pick up my truck later today. I am worried that the shark fin will cause an issue. I ordered a F350 SRW 6.7 CCSB Fx4.
Old Sep 14, 2018 | 03:44 AM
nascarjimmy's Avatar
nascarjimmy
good luck.
Old Sep 14, 2018 | 11:21 AM
GMoney1121's Avatar
GMoney1121
If you could report back on the affect of the fin, that would be great. If it’s going to be an issue, I can start planning for changes now before the truck comes.
Old Sep 14, 2018 | 06:11 PM
slip knot's Avatar
slip knot
My F250 XLT didn't come with the fin, just a round button. But I didn't get the navigation package either.
Old Sep 14, 2018 | 08:38 PM
Tx.Hoon's Avatar
Tx.Hoon
I picked up the truck. There was a wreck on I-10 (no surprise). By the time I got home it was time to take the wife to dinner so i will have to wait until tomorrow to do any specific measurements. I will update after I check. Attached is a picture. I am thinking it MIGHT be a little taller than the rear of the cab but not sure yet. It will be close either way.
Old Sep 15, 2018 | 11:39 PM
Tx.Hoon's Avatar
Tx.Hoon
Ok, managed to get time to pull it in on my side of the garage. My seal on the bottom of the garage door header is 82.5" You can see that there is a little clearance for the shark fin. I have a bunch of crap in my garage on my side so I can't pull all the way in to check the rear of the cab. I still think the shark fin might be the tallest thing on the roof. I will try to get the shark fin and the rear of the roof measured tomorrow to see what is the tallest part.
Here is the pic.
Shark fin LTE Antenna on 2019 F350 CCSB 6.7. No sno plow or camper package.
Old Sep 16, 2018 | 02:03 PM
GMoney1121's Avatar
GMoney1121
I’m going to have to go measure my garage door to see exactly how tall it is.
Old Sep 16, 2018 | 09:33 PM
rashers's Avatar
rashers
I can't quite make out how your door works but assuming it's a somewhat regular overhead door, you probably have stops that stop the door when it's all the way up. You may be able to adjust it by a few inches and get it to go a little further and lift the end a bit higher.
Bugzilla46310
Feb 2, 2019 01:11 PM
Markken
Aug 23, 2018 10:11 AM
Rob89
May 19, 2018 11:59 AM
EightySecond
Dec 30, 2017 12:41 PM
SlickYamaha
Nov 20, 2011 08:37 PM
