Over heating in the drive through.
Old Sep 5, 2018 | 01:43 PM
Bandit89's Avatar
Bandit89
I’ve got a 6.8l v10 X and I’ve only had it for about 3 weeks now. I bought it from a dealer in Arlington and drove it back home about 300 miles. Ran great. But a week later I was sitting in the drive through for far too long (slow workers) and the engine started getting hotter and the air conditioner stopped blowing cold air. Anybody else experience this with the v10? It might be normal. It only got up the 3/4 on the temp gauge. I’m replacing the thermostat today to see if that helps.
Old Sep 5, 2018 | 02:02 PM
wpnaes's Avatar
wpnaes
Worth a look. When that fan clutch engages you won’t miss hearing it.
https://www.ford-trucks.com/forums/1...l#post15048442
Old Sep 5, 2018 | 02:56 PM
Bandit89's Avatar
Bandit89
Thanks for the idea. I hear the fan on. I don’t feel any play in the bearing. I’ve considered that. If the thermo doesn’t fix it I might replace that to be on the safe side. I’ve also been thinking of addin a fan in front of the radiator. I live in West Texas and the temps get up to 110 so sitting in a drive though get pretty hot.
Old Sep 5, 2018 | 03:20 PM
BassFantasizer's Avatar
BassFantasizer
You might get some non-acidic coil cleaner and make sure that the radiator and A/C condenser coils are clean, too. If they can't exchange heat easily you'll get the symptoms you described.
Old Sep 5, 2018 | 03:36 PM
Bandit89's Avatar
Bandit89
I’ll give that a try as well.
Old Sep 5, 2018 | 05:41 PM
WE3ZS's Avatar
WE3ZS
Get yourself some sort of ODBII reader to show you the actual cooling water temperature, the dash gauge is actually only a multi-position idiot light and is far from accurate. The Torque app is very popular and cheap used along with a proven OBDII dongle.
The engine temp getting hot sitting at the drive through doesn't really explain the air conditioning getting warm at the same time, the AC condenser is in front of the radiator and first in line of the air flow through the stack.
Did the engine actually "overheat" (as in boil over coolant from the expansion tank) or did it just see some elevated above normal temps?
Old Sep 5, 2018 | 06:43 PM
Bandit89's Avatar
Bandit89
Just elevated the temp a little. No boil.
Gunnerboy
Jul 28, 2017 07:12 AM
fordsuperduty250
Aug 8, 2012 09:01 PM
redmt77
Apr 1, 2009 08:36 PM
depotops
Jan 16, 2007 03:46 PM
holechit
Modular V10 (6.8l)
Aug 6, 2004 10:12 PM
