Getting back body lines
Old Sep 4, 2018 | 08:50 PM
ReissL's Avatar
ReissL
I’m currently working on a frame of restoration on a 1978 f150 Custom. The previous owner had put 79 ford bedsides on a 93 ford bed. On top of swapping over the sides he used a patch panel on the wheel arch (from lmc) to rid the rust in that area. I’ve really come to hate the fact that LMC panels lack the body line on the wheel arch. So now I am looking to get the body line back. I’ve looked into panels but I don’t feel like warping the bed. I’ve decided I would like to use filler to get the line back (fiberglass and bondo over it) but not all sure how to go about getting it right. I though about getting a form out of plastic or silicone on a bed that has the line so I can then build it correctly. I’m just really perplexed as to how I would even get the form to do it though. If anyone can help me out here it would be very appreciated. Thanks for reading all of this and helping me out. The body line must come back
Old Sep 4, 2018 | 10:03 PM
bryanmartin's Avatar
bryanmartin
I hate to break it to you, but there is no way to do what you're suggesting "correctly". Even the best filler in the world (better filler allows higher build) recommends no more than 1/16" of build up. Any more than that and it will crack in very short order. I limit my filler work to less than half that. Really the only way to do this properly is to learn body work so that you can weld in better (or OE) panels without warpage, or at least know how to fix it when it happens. Or you could pay someone to do it.
Old Sep 4, 2018 | 10:16 PM
meangreen92's Avatar
meangreen92
You can still try it. I built the lower rear quarters on my old '68 Cougar out of Bondo and it never cracked. It was thick too. I mean I built everything from the rear of the wheel openings back to the valance panel, and it was thick. It wasn't the right way, but it looked good.
Can you post up pics of what you're working with?
Old Sep 5, 2018 | 12:31 AM
ReissL's Avatar
ReissL
I will get some pictures tomorrow, the other guy that commented was saying that there is no proper way to do it. I’m sure it isn’t the right way but it will be better than no body line. The previous owner did a great job with the patch but it has no body line at all. I’m just curios even if I do build the line out of fiberglass and bondo how I will get it to be the correct shape
Old Sep 5, 2018 | 12:36 AM
mark a.'s Avatar
mark a.
Can't you find a good used bed in your area ?
Old Sep 5, 2018 | 12:38 AM
ReissL's Avatar
ReissL
Good point but it made me laugh a bit actually. There is no such thing as a good used shortbed in north jersey. It would take years to find
Old Sep 5, 2018 | 07:13 AM
FuzzFace2's Avatar
FuzzFace2
1/16 thick is nice but you can go to 1/8" and have issues but thinner is better.
Now you did not say how much it needs to come out, your skill set, thinking low if using glass & filler and the big one what tools you have to fix this with?
You could weld coat hanger wire bent in the shape you need to do the edge then grind to shape better and filler to finish it off.
Dave - - - -
Old Sep 5, 2018 | 01:48 PM
ReissL's Avatar
ReissL
Dave - - - -
I don’t think it has to come out much at all. Again, I have nothing to reference the body line off of at the moment. Here are some pictures of what I’m working with. Dosent need much just want it better than what it is. And I’m really just looking into how to go about it. I’m not experienced with body work but I’m also not an idiot and want it done right.
Old Sep 5, 2018 | 02:00 PM
ReissL's Avatar
ReissL
Old Sep 5, 2018 | 08:05 PM
bulldogcountry1's Avatar
bulldogcountry1
My truck originally had the lower rack track molding. About 15 years ago, I removed it and welded up up the holes. I didn't have much time to fix it properly because it was my dad's daily driver. At every attachment point on the wheel arch, the sheet metal was pulled out about 1/16". I've been working on the body for a year now, and I'm ready for paint. Getting those wheel arches acceptable was quite a pain. It's about impossible to get that crisp body line back.
Old Sep 5, 2018 | 10:22 PM
todd jo's Avatar
todd jo
I know it’s not what your after, but long beds are a dime a dozen compared to SB. It might be worth considering shorten a correct long bed. It certainly can’t be worse or any more expensive in the long run. Look at what your up against now!
Diesel 724
Oct 5, 2013 11:14 PM
FunknFord
16
Feb 11, 2011 06:37 PM
78ihs2
Paint & Bodywork
Oct 1, 2009 10:50 AM
webb601
Paint & Bodywork
Nov 26, 2006 05:04 PM
