Sponsored by: Real Truck
liitle rear block help please
Old Sep 3, 2018 | 09:14 PM
sikfish's Avatar
sikfish
OK i am finally getting around to putting in 1" blocks on my 02. I previously put in a front leveling kit and it was a bit high. I dont really like high lifts since i use my truck. But, i started installing 1" aluminum blocks and said no way. My question is i dont want to stack blocks now that i look at it. What height blocks and ubolts should i get to toss the factory blocks and raise 1"? 3 " blocks? Anyone know the best place to get a kit with ubolts?
thanks
Old Sep 4, 2018 | 11:55 AM
slpcth's Avatar
slpcth
Don't know what height lift blocks you will need but check out Top Gun Customz for lift blocks.
Old Sep 4, 2018 | 12:39 PM
02TB250's Avatar
02TB250
Measure the truck as it sits right now. Figure out if you want to go up or down. PMF suspension makes blocks in 0.5" increments I believe topgun customs makes them as well so you at least have options. But decide where you need to go in height and then the appropriate block and ubolts. Having one block is much better and safer then stacked blocks.
mdula
Jul 15, 2011 09:14 AM
Gage2502
Mar 7, 2011 02:26 PM
shadow_almanza
15
Aug 25, 2010 08:46 AM
mbogosia
2004 - 2008 F150
17
Jun 5, 2007 09:01 PM
rosco_p_coltrane
Aug 20, 2006 03:54 PM
