egr delete vs block off debate
Old Sep 3, 2018 | 06:06 PM
17f2fiddy's Avatar
17f2fiddy
so iv decided on the no limit tyrant tunes ez lynk with sotf for my 17 , now i can't decide on full egr kit with pass thru or the block off plates...iv deleted a 13 6.7 for a friend in the past wasn't terribly bad, but is there any pros/cons or gains in removing the cooler, any benefit to the engine? any chance of it failing? like on the 6.0/6.4? just not sure if i should remove the entire cooler/egr or just remove the pipes, unplug harness and install the 4 no limit plates.
Old Sep 3, 2018 | 09:09 PM
UGA33's Avatar
UGA33
Most guys remove it to clean the engine bay up. It is a lot safer to leave em on the trucks since the EGR valve is on the hot side of the coolers now. The 6.0 and 6.4 had the valves on the cold side, which allowed the gasses to flow through the cooler. They then dead headed at the valve that is electronically closed. On the 6.7s, the valve is on the hot side. So with it closed, no gasses make it into the cooler. This gives you less risk of a cooler rupturing from hot/trapped gasses.
Best route if you plan on leaving the cooler on the truck is to run block off plates. This removes the EGR crossover tubes.
Old Sep 3, 2018 | 10:25 PM
cappa's Avatar
cappa
Block off plates get my vote. Removes the piping to the egr on both sides so no chance of it failing, and the coolant still flows thou the cooler so no chance of dead heading the flow. Gives you a accurate spot for a egt probe as well. Way less labor, easily reversible if needed. I have that no limit set by the way, fits like a dream
Old Sep 5, 2018 | 06:50 PM
17f2fiddy's Avatar
17f2fiddy
ordered my no limit block off plates today, and ezlynk tyrant tuning and the 4" dpf delete pipe, Do you unplug the connectors to the egr system? i know on the dpf you obv have too i was going to pack di-eletric grease in them and then cut the finger of a rubber glove to try and seal it. what did you guys do with the def system just leave it as it nothing to unplug or drain?
Old Sep 5, 2018 | 08:12 PM
cangim's Avatar
cangim
agreed, this is the route I took with my '16. Looks like I soon will have an annual wrench party to meet emission inspections come 2019...
Old Nov 25, 2020 | 10:38 AM
DrillbitTailor's Avatar
DrillbitTailor
I am new to all of the discussion on EGR issues. I have a 2012 6.7 with 80K miles on it. I have been getting about 17 mpg when not towing. A month ago I had the check engine light come on and I swung by the dealer to have them pull the code. It is for an EGR temp sensor. Told me Ok to drive until I have time to do without the truck and they can fix it. I have driven about 800 miles not towing anything, driving non interstate roads since then and I am getting 21 mpg! It was 22 until regens kicked in and dropped it. This is the best mileage I've ever gotten. If not fixing these sensors won't cause problems, I'd be thrilled to leave it alone. Can anybody definitively explain why the failed sensor could result in a 4mpg (23%) improvement in mileage, and if so will this cause problems down the road?
capt caper
6.7L Power Stroke Diesel
Jan 7, 2019 05:55 AM
Robert Green
6.4L Power Stroke Diesel
Jan 19, 2018 01:22 PM
Justus6.0L
Feb 15, 2017 09:28 AM
rhjj
Dec 4, 2016 12:09 PM
BFlemsr
Nov 16, 2012 06:38 PM
