Help me decode this vin
Old Sep 1, 2018 | 04:48 PM
Hanks other son's Avatar
Hanks other son
I just scored a 1960 f250 4x4 the vin is F25 C0 R17967 118" wheel base color is F which I assume is white because that's the color on the glove box door model is f253 date 06L trans F axel 04B max gvw 7400 and what is DSO 6679 so there you have it, your efforts and info would be greatly appreciated Thanks Brian W.
Old Sep 3, 2018 | 01:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Hanks other son
I just scored a 1960 F250 4x4
F25C0R17967 / WB: 118" / COLOR: F / MODEL: F253 / DATE: 06L / TRANS: F / AXLE: 04B / MAX GVW LBS: 7400 / CERT NET HP: 135 / RPM: 3600 / DSO 6679 .
F25 = F250.
C = 292 2V
0 = 1960.
R = San Jose CA Assembly Plant.
17967 = 1960 Numerical Sequence of Assembly, the trucks specific serial number.
118" Wheelbase,
F = Light Blue (M = 1960/63 Corinthian White).
F253 = F250 4WD, 7,400 lbs. GVWR
06L: Assembled November (L) 6, 1959.
F = Borg-Warner T-98 4 Speed Manual Transmission).
04B:
04 = Spicer/Dana 60 Rear Axle / 4.56-1 / 5,200 lbs. Rear Axle Capacity.
B = Spicer/Dana 44 Front Driving Axle / 4.55-1 / 3,000 lbs. Front Axle Capacity.
7,400 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,600 RPM
6679 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Sep 3, 2018 | 08:11 PM
Hanks other son
Thank you Bill, that was everything I was looking for and then some. Have a great labor day weekend. Brian W.
IronPlayer66
Jun 8, 2015 07:22 PM
mrgoob
Sep 23, 2012 07:52 AM
mrgoob
Sep 22, 2012 12:27 PM
fordtruck60
Aug 19, 2012 09:13 AM
oldford65
Nov 28, 2011 03:27 AM
