2018 no sync
Old Aug 29, 2018 | 06:27 PM
2018f250stx's Avatar
2018f250stx
2018 no sync
My 2018 do with Stx package didn't come with sync, has anyone added the basic sync I don't need the big screen from sync 3 but miss having bluetooth
Old Aug 29, 2018 | 06:48 PM
h20camper's Avatar
h20camper
I'd try an aftermarket unit. Aftermarket will give you bluetooth and CarPlay/Android Auto. You probably don't have steering wheel controls??
See these threads.
https://www.ford-trucks.com/forums/1...head-unit.html
https://www.ford-trucks.com/forums/1...es-please.html
Old Aug 29, 2018 | 06:54 PM
2018f250stx
See these threads.
no steering wheel controls , I'd like those back also. I thought about aftermarket but I'm afraid of losing the active markers on the backup camera
Old Aug 29, 2018 | 07:04 PM
h20camper's Avatar
h20camper
Originally Posted by 2018f250stx
no steering wheel controls ,I'd like those back also. I thought about aftermarket but I'm afraid of losing the active markers on the backup camera
I'd think you be looking at quite a bit of work and expense to add everything for Sync. Not sure active markers are worth that. I have the markers, they just don't 'move'. I wonder if there is a FORScan setting to enable them???
Old Aug 29, 2018 | 07:15 PM
2018f250stx
your camera markers don't move when you turn your steering wheel??
Old Aug 29, 2018 | 07:55 PM
h20camper's Avatar
h20camper
No. My truck is a 2017 and didn't come with a back camera. I was able to add the Ford OEM camera and enable to my Sync. The lines weren't active with it but maybe I missed a FORScan setting. They weren't overly important to me. I recall someone posting a FORScan setting about it. Trouble is me finding it again.....
Old Aug 29, 2018 | 08:01 PM
2018f250stx
if you find the location of that in forscan ill check what mine is and let you know, do you know if the idatalink will send the active markers with the rear camera pic?
Old Aug 29, 2018 | 08:29 PM
h20camper's Avatar
h20camper
According to this, its supported.
Old Aug 29, 2018 | 08:32 PM
2018f250stx
https://www.youtube.com/watch?v=_tP3QzEhdjI
cool, i think this is my answer, i can add wheel controls later, thanks
Old Aug 29, 2018 | 09:39 PM
h20camper's Avatar
h20camper
I found the post I was looking for. Can you check BdyCM address 726-39-02 and see what the 6th digit is set to?
Old Aug 30, 2018 | 05:50 AM
2018f250stx
I found the post I was looking for. Can you check BdyCM address 726-39-02 and see what the 6th digit is set too?
ill check it after work tonight
Old Sep 1, 2018 | 07:58 AM
2018f250stx
Old Sep 1, 2018 | 09:42 AM
h20camper's Avatar
h20camper
Thank you .
Old Sep 1, 2018 | 09:45 AM
2018f250stx
Thank you .
I was ready to pull the trigger on the same kenwood as yours but cruthfield says it's discontinued
Old Sep 3, 2018 | 05:16 PM
h20camper's Avatar
h20camper
The 9903 is an older model. Its available here as well as the 9904. I think the only difference is the 9904 doesn't have the HDMI input like the 9903 does.
https://www.soundoftristate.com/car-...03s-w-kh-kr900
https://www.soundoftristate.com/car-...celon-ddx9904s
