'95 heater control problem
Old Aug 12, 2001 | 04:40 PM
mossberg's Avatar
mossberg
I recently purchased a 1995 Econoline 250 with a/c. The problem I am having is that the damper door control only wants to blow out of the defrost vents. I have the dash semi-apart and can not find the location of the "door". I also can see that there is vacuum and eletric controls on the selector switch. The vacuum control for the max a/c is working, as is the eletrical motor for the heater/temp control "door". I need help in diagnosing this one. Is the distribution door vacum of eletrically controlled? Where is this door and it's controls located? Thank you in advance
Old Aug 13, 2001 | 06:52 PM
mossberg's Avatar
mossberg
bump
Old Aug 14, 2001 | 01:44 PM
mossberg's Avatar
mossberg
I'm still looking for some help on this one.
Old Aug 15, 2001 | 12:42 AM
walterdanek's Avatar
walterdanek
Hey Moss, don't know if it helps, but on my '84 the door is right after the blower under the glovebox.
Happy hunting & good luck
Walter
Old Aug 15, 2001 | 07:21 PM
mossberg's Avatar
mossberg
No glovebox in my Econoline . Any more help out there??
Old Aug 15, 2001 | 09:37 PM
Torky's Avatar
Torky
94 book info - Function door is vac controlled. Function door vac motor has a blue hose. No vac on blue, air heads towards defroster door. With vac on blue, Function door closes to defrost door area, and opens to the panel/floor area.
Function door is downstream from the Blend door.
FYI, Defrost Door vac motor has a yellow hose and a red hose.
Blue hose may have a tee connection to "Aux" also. Don't know what that is, maybe to a rear unit if equipped?
Aren't dash guts fun to explore?
Old Aug 19, 2001 | 08:33 PM
mossberg's Avatar
mossberg
torky, thank you very much, and yes, I'm having a blast in the dash!!!!
Old Aug 19, 2001 | 11:39 PM
Fordinmyname's Avatar
Fordinmyname
