1978 - 1996 Big Bronco
Smog Pump
Old Sep 23, 2003 | 07:29 PM
AYoungblood's Avatar
AYoungblood
Smog Pump
I did a search and didnt come up with anything specific.
What EXACTLY is a "smog pump", and i assume it robs HP from the engine.
Where is it located and do i need it?
Thanks a lot guys,
Adam
Old Sep 23, 2003 | 07:50 PM
frogger01's Avatar
frogger01
Smog Pump
The smog pump is an air pump that injects air into the exhaust to dilute it. To tell you the truth it doesn't take much HP away and can cause your catalitic converter to fail if it is not hooked up.
Old Sep 23, 2003 | 08:28 PM
Gacknar's Avatar
Gacknar
Smog Pump
If yours still works there is no reason to remove it. According to Muscle Mustangs and fast Fords the paracidic drag coused by a smog pump is only measurable in the thosanths of a horse power.
In my case mine was removed by my Dad in 1993 before the Bronco was mine so I had no choice in the matter.
Old Sep 23, 2003 | 08:40 PM
AYoungblood
Smog Pump
Gacknar:
How hard was that Mustang 93 conver.?
And how much did it cost?
Did you notice a drop in MPG?
Where did you notice the biggest improvements?
Adam
Old Sep 23, 2003 | 09:41 PM
RJR99SS's Avatar
RJR99SS
Smog Pump
i've removed the smog pumps on a few vehicles. I've never noticed any difference at all in power or gas milage.
The only reason i would remove one would just to free up space under the hood.
If you remove the smog pump, you might as well remove the cat as well. The two work together. Having one and not the other makes no sense at all.
Now...by removing the cat you'll notice a little more power and gas milage. Of course this may be impossible depending on the emission laws in your area.
Old Sep 24, 2003 | 01:21 AM
AYoungblood
Smog Pump
MI, suppose there is no checks... but i know you cant take them off... but......... ummmmmmm yeah i wont
at my cats
Adam
Old Sep 24, 2003 | 08:18 AM
Gacknar's Avatar
Gacknar
Smog Pump
AYoungblood
look here for more details on the conversion.
https://www.ford-trucks.com/forums/s...hreadid=142747
and it did eventualy pass emissions.
https://www.ford-trucks.com/forums/s...hreadid=155146
Adam Wider
Nov 1, 2012 11:16 PM
Adam Wider
Nov 1, 2012 06:13 AM
redfire42
51
Jun 16, 2009 12:42 AM
AYoungblood
Michigan Chapter
Sep 21, 2003 04:09 PM
bmrsnr
Mar 7, 2001 10:15 PM
