Timing Is Off?
Old Oct 31, 2012 | 09:40 PM
Adam Wider's Avatar
Adam Wider
Timing Is Off?
Hey Fellas,
I just bought a 1989 4x4 Ford F-150 5.0L 302 5 speed manual and I failed my smog test for CA. I was told the air injection, catalytic convertors and timing were the issues. Does anybody have information on what might have failed the air injection and the timing if the gun read 8 points retard? Supposedly this would make the truck gutless since it is 18 points off what it's supposed to be at... However... It doesn't seem to be. Any info would be greatly appreciated.
-Adam
Old Oct 31, 2012 | 10:22 PM
Papa Tiger's Avatar
Papa Tiger
U probably need new cats/muffler and tune up, & possibly the distributor. Also look into the PCV and hose. Clean the smog control up some. I'm thinking in print.
Old Oct 31, 2012 | 10:39 PM
85e150's Avatar
85e150
Originally Posted by Adam Wider
Hey Fellas,
-Adam
Welcome to FTE. I hate to answer a new member like this on this issue, but:
The seller is supposed to smog the vehicle before selling. Per state law.
Take it back and get your money back. The cost of new cats and whatever else it needs is probably more than you paid for it. Sorry.
Old Oct 31, 2012 | 11:22 PM
85e150's Avatar
85e150
If for some reason you can't get your money back and can't sue the guy:
--did you get a printout from the smoggy?
--note Magnaflow shows CA approved replacement cats for your truck. It uses 2.
Old Nov 1, 2012 | 12:09 AM
Adam Wider's Avatar
Adam Wider
I did buy it in Nevada... does that matter?
Old Nov 1, 2012 | 12:10 AM
Adam Wider's Avatar
Adam Wider
I have seen the cats and yes I have the print out.
Old Nov 1, 2012 | 12:14 AM
TheStuffz's Avatar
TheStuffz
might have better luck in the correct year part of the forum
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Old Nov 1, 2012 | 09:51 AM
85e150's Avatar
85e150
Not sure on Nevada law, but I doubt it requires a smog. What does the print out read? CO, CO2 NOX, HC etc. The standard and what your truck blew.
Old Nov 1, 2012 | 04:11 PM
oldford96's Avatar
oldford96
A couple possible causes for the timing issue; The distributor at some point was removed and re-installed incorrectly, or depending on the mileage, the timing set is stretched/worn.
Old Nov 1, 2012 | 11:16 PM
85e150's Avatar
85e150
In addition to the other questions regarding the smog test results, where is is currently registered? Did you buy it private party? Is it a 49 state vehicle or a CA vehicle?
If it's a CA vehicle, there should have been a smog history on it. If the air injection is missing, it was probably removed by the PO. Unless it just rusted off....in which case you'd have other issues....
Anyway, let us know. The smog numbers can tell the tale on the cats and which way to go.
Adam Wider
Nov 1, 2012 06:13 AM
NBC-Steve
Dec 4, 2011 04:34 PM
77blue
37
Dec 3, 2011 11:51 AM
axman_F250
Mar 16, 2011 04:47 PM
dbuck50
27
Nov 28, 2003 11:34 PM
