5200 lb spring part number
Old Aug 28, 2018 | 09:46 AM
Kohrfam's Avatar
Kohrfam
Anyone have the part number for the 5200 lb front coil spring? Just got a new Platinum cclb with the plow pack and it is a buckboard compared to the others I test drove. It was "used" with 28 miles, so too good a deal to pass up.
thanks for the help
Old Aug 28, 2018 | 10:46 AM
Kohrfam's Avatar
Kohrfam
Part number I found is
5C3Z-5310-EA
T code spring.
can anyone confirm if this is the softest 4wd diesel spring?
Old Aug 28, 2018 | 12:16 PM
bitNine's Avatar
bitNine
Subscribing. I am in the same boat, and would like to replace those springs.
And holy crap, at $110ea, is there a cheaper/better aftermarket alternative?
Old Aug 28, 2018 | 12:19 PM
Tricon's Avatar
Tricon
I have those springs in my garage, but I'm sure they would be expensive to ship from SoCal. You could always call up Eibach or any of the big spring manufacturers and see if they would spin you a coil.
Old Aug 28, 2018 | 12:21 PM
ArcticCircle's Avatar
ArcticCircle
For what its worth, I have a 17 CCSB F250 Platinum 6.2 and I am assuming this truck has the softest spring available in a 250. Part number 5C34-5310-AGD
Old Aug 28, 2018 | 01:36 PM
Havudrvnafordlately?'s Avatar
I'm in a 2018 CCSB 250 6.7 that has the camper package on it and it has either the 5c34-5310-AGD or ADD springs. I am almost certain the D code is for a 5600 lb spring. I am looking for the lowest you can go too, but I think the answer is 5200 lb. I changed out the stock struts/shocks for Rancho's and the front end still rides extremely rough. I like a firm ride, but this is well beyond that.
Old Aug 28, 2018 | 02:41 PM
Rtr2017!'s Avatar
Rtr2017!
5C34-5310-AEE is the correct 5200# spring. I started a thread on the same thing, wondering what mine was rated. I have a 19 F350 CCSB with camper package. Took this part # right off the front spring.
Old Aug 28, 2018 | 02:42 PM
Kohrfam's Avatar
Kohrfam
Is your truck gas?
Old Aug 28, 2018 | 02:44 PM
Kohrfam's Avatar
Kohrfam
Thanks for confirming the part number. Just checking to be sure I get the lowest approved spring for the truck.
Old Aug 28, 2018 | 04:29 PM
Race Red F-250's Avatar
Race Red F-250
thanks for the help
May be interested in the CC springs. Putting on a full replacement bumper and want to try and level things out. Message me once you get things swapped out if you’re interested in selling. Thanks.
Old Aug 28, 2018 | 06:03 PM
Rtr2017!'s Avatar
Rtr2017!
Yes, gas motor
Old Aug 29, 2018 | 02:43 PM
Kohrfam's Avatar
Kohrfam
Have some new springs ordered. I'll update everyone when installed. I'll let you know on selling my springs.
Old Aug 29, 2018 | 02:44 PM
Kohrfam's Avatar
Kohrfam
Which Ranchos did you install?
Old Aug 30, 2018 | 05:54 AM
LiquidSteam's Avatar
LiquidSteam
I have a 6.2 with no camper or snow plow package and it came with 5600lb springs. I was under the impression that they were the lightest duty springs for the Super Duty
Old Aug 30, 2018 | 12:13 PM
RS9000XL's. They are a huge improvement over stock even with the firm springs. Setting 5 on the fronts gives the softest ride on rough pavement, but it feels too bouncy for my taste on the highway. Setting 6 on front gives a great highway/smooth pavement ride with little to no bounce, but is very rough on anything less than perfect pavement. I am wondering if the 5200 lb spring will soften the front end up just a bit and maybe then I can run on setting 6 and have the best ride on any kind of pavement.
