Adjusting LED headlights
Old Aug 27, 2018 | 08:41 PM
EdwardC's Avatar
EdwardC
So I've had my truck lifted with a 4" BDS kit and I'm tired of being flashed as I drive down the road at night (im sure people are tired of being blinded by my bright *** lights too
I went to adjust the lights via the screw adjustment and as I tried to turn it, it wasn't budging. I didn't want to give it too much torque and break something. For those of you who have adjusted the lights, how much force was needed? Am I being a lil B and should I just use more force?
anyway, these are the screws I was trying to turn. I hope they are the right ones.
Old Aug 27, 2018 | 08:51 PM
EdwardC's Avatar
EdwardC
Let me clarify something...its not that the screws wont budge, they actually do turn but they feel like they are spring loaded. After turning 1/4 turn or so they spring back into place. I don't want to force them and end up breaking them because I'm doing something wrong. Thanks for the help.
Old Aug 28, 2018 | 11:02 AM
nuctrooper's Avatar
nuctrooper
Yep. They feel very "plasticy". I worked mine back and forth a bit until the screw moved, then down (tighten) 1-1.5 full turns. Not a very comforting feeling, but they turned. Once they broke free, they were much easier to turn.
Others here have reported breaking the adjustment screws and having them successfully replaced under warranty.
Old Aug 28, 2018 | 08:19 PM
Toohigh's Avatar
Toohigh
Nuctrooper
good idea working them back and forth. Any other tips getting them to break free?
I would really like to avoid a warranty discussion.
Old Aug 28, 2018 | 08:41 PM
K-tung's Avatar
K-tung
Try WD-40 or a penetrating oil. My passenger side broke while I was turning it and the dealership replaced the entire unit under warranty
Old Aug 28, 2018 | 08:53 PM
docup!'s Avatar
docup!
I tried adjusting them after my level. One side worked but very slowly gave way and bound up. the other started to give but was binding up as well then snapped. I got it covered under warranty they had to replace them entire light housing over 1200.00. Be very careful if they don’t give bring it to the dealer let them snap it.
Old Aug 28, 2018 | 09:02 PM
0835064's Avatar
0835064
I had good luck with a spray Teflon dry lube after breaking one and getting it warranteed. Now they both smooth as butter, didn’t like the idea of spraying with a oil based lube.
Old Aug 29, 2018 | 07:32 AM
Toohigh's Avatar
Toohigh
That sounds like a great idea. How did you get the lube in the right spot?
Old Aug 29, 2018 | 10:10 AM
0835064's Avatar
0835064
If you leave ok down the back of the light housing you can see the gear set. I just shot at it liberally and moved the gears back and forth.
Old Aug 29, 2018 | 09:09 PM
Toohigh's Avatar
Toohigh
I found those gears and will give that a try. Thanks very much.
Hayguy
Nov 12, 2016 11:04 PM
teardropty
Dec 14, 2011 04:16 PM
chaser1602
Apr 18, 2008 05:12 PM
ranch67
1947 and Older Ford Trucks
Jun 9, 2007 05:18 PM
1bad71F100
Jan 23, 2006 03:14 PM
