Clutch pedal/action broken
#46
#47
If by 'covering' the pedal you mean holding your foot on it while driving, then no. Floating is where you shift with no clutch, all RPM matching.
That's good that your trip is mainly interstate, I was afraid it'd be partially in town and you'd end up in a situation similar to mine when my clutch went out - hitting a red light with no clutch (somehow while rolling backward first grabbed and didn't stall sending me back on my way).
The pedal cannot go any higher and the push rod sits just inside the master cylinder. I think it will get us home, and I will fix it then.
#48
I had the same thoughts. I will probably get a LUK assembly from Rock Auto and the parts Timmy posted for the Heim mod. I plan to see how difficult it is to remove the pedal assembly in order to see about repairing the spring bushings.
#49
edit: downshift rev matching, not upshifts
#50
#51
Seems like it took a bit of cussing and contortion to get the pedal out. It's not hard to do, just no room and hard to reach. It's just a pin with clips on the end. Remove a clip, take the spring off the pedal, then slide the pin out. Just not a whole lot of room to get the pin out.
#52
Thanks for the advice on the pedal, I thought I was going to have to unbolt the entire assembly from the firewall based on a glance at it.
#53
No, you can get it out with just the pin. Look carefully. Seems like I tried going one way with it and ended up having to pull the pin the other direction. But it's been a while so I don't remember all the details. I just know I got it out. Unbolting it seemed like a bigger hassle.
I also have stuff I can stack up that's level with the floor so I can lay on my back and get up under the dash without having to twist my body too bad. Pulling the front seat makes it easier too. If you've got captains chairs, it's only 4 bolts.
#54
You a just full of good ideas. I have all sorts of stuff to stack and make a platform. I might have to get a picture of that too just for laughs.
I do have captains chairs. Although I fear if I remove one I may be forced by OCD to remove everything to clean it.
Thanks again for the info and ideas.
#55
#56
#57
Yo Sous..back from gods country..so, yeah..Chris got you covered..1 thing ill ad, you must remove both clips and remove pin toward passenger side. If you look closely on driver side, They(ford) massaged the metal and made an impression for the pin to hit so there would be enough room on driver side, but they failed miserably...when removing pin toward pass side, youll fish it threw the loom of wires. Again, they failed miserably BUT it can be done...they pin plastic bushings..BE CAREFUL because THEY only sell them with the PEDAL ASSY....
1) hold hand on clutch pedal and remove master rod
2) release clutch pedal slowly to remove spring
3) remove both clips with grout pic
4) have fun fishingbpin out
#58
I don't know if I have enough talent to do that. I do rev match when shifting even with the clutch, but think I would be pushing my luck shifting without the clutch. Especially with the trailer in tow.
I can attest that when I use the clutch, these trucks shift smooth as butter. My buddy was picking on me a couple weeks back that the way I shift people probably think the thing is an automatic.
On my way home I got to thinking, your return spring is still hooked up, isn't it? If you removed that it should help keep the rod in the master - nothing would be trying to pull it out when your foot comes off the pedal.
#59
Made it home today without any issues. Just had to bring my leg up twice as high to push the clutch in. I will get the parts on order in the next day or two and swap them out.
Thanks to everyone for the help in getting the issue figured out and the advice on some of the mods being considered.
