Sponsored by: Real Truck
Frame swap
Old Aug 27, 2018 | 11:38 AM
Sycobilly911's Avatar
Sycobilly911
Frame swap
I have a 99 f-250 super duty longbed 4x4 with the two half doors on the cab ( not sure if that's called crew cab or what ) my frame is rusted to an extent the truck isn't safe to drive. My question is , what other years will work for a frame swap ? Thanks.
Old Aug 27, 2018 | 03:01 PM
SuperDutyScaler's Avatar
SuperDutyScaler
99 to 2004 is a direct swap
2005 to 2010 body will swap over but you'll have coil sprung front suspension and differnt motor/trans. 05 up is a big deal for suspension swaps on the 99-04 trucks....some think the ride is better
Old Aug 31, 2018 | 04:05 PM
Destroked 450's Avatar
Destroked 450
The 05 up coil bring front is worth it for the shorter turning radius.
As said 99-04 is direct swap
05 up you'll need the suspension and steering to go with the frame.
Old Sep 1, 2018 | 07:07 AM
I.B. Washincars's Avatar
I.B. Washincars
Your truck is called a Super Cab.
Olweldinrig
64
Oct 7, 2013 12:52 AM
Nsaan
Apr 4, 2013 05:07 PM
93 mix 'n match
1997 - 2003 F150
Apr 6, 2010 08:45 PM
rpemsweet
Jan 11, 2007 07:24 PM
lars915
Aug 29, 2003 11:20 PM
