Finally reached a crossroads........
I REALLY do not want to have my truck start running in the
salt full time. After being able to keep the truck off of the salt
for the past 6 or 7 years I don’t want to give up.
So I think my options are this
1.) Lease a vehicle to eat up the salt. I’ve grown tired of fixing salt destroyed car parts. Leasing is just giving your money away but someone else can deal with the salt later. But lease payments are not exactly cheap.
2.) Trade in the truck and look at the 17+ trucks in hopes the aluminum bodies can handle the salt. Steel parts will still see abuse though. Biggest problem here is $$$ in that new trucks are super expensive and my truck is probably the most valuable to me in terms of trade or sale. Would definitely be looking at ordering as I would be looking at a F550.
3.) Deal with tha salt and try my best to keep it at bay. It’s a losing battle that will take its toll.
Luckily it’s only August so the snow won’t be around for a while.
My '11 has never seen winter. It's mint, seems it'll last in definetly. This winter I'll drive my '95 I think and laugh at the salt and gravel and wear and tear that winter throws my way. I'm up in BC Canada and instead of cringing every time I pass by another vehicle all winter long for fear of rock/gravel dings I just drive an older truck all winter. Rock chip? Who cares. Salt corrosion? We'll call that patina. Lol.
Seems like a lot of Jeeps with the 3.7L V6 are going 150k+ on the engine and transmissions, fly south and find a Liberty with 100-120k on it and it should last at least three-five years depending on what you do/ don't do to it. Parts are cheap, the engine bay is huge, the interior isn't worse than an Escape (IMO both are tiny, 2004 Escape compared to 2008 LIberty). I just sold one with 165k and drivetrain was in great shape, just body was rough from my wife bumping things and we needed more interior room for carseats.
Keep all seams, wheel wells, or any other dirt collection points clean. Once a year in mid October: WD-40 (or equivalent) all seems (hood, doors, tailgate, under hood) and squirt it inside drain holes using the provided straw. Also once a year: Good dose of Fluid film on everything underneath (except for the exhaust system). I actually use new motor oil but starting to shift towards fluid film. Applied with an airless sprayer to spray directly into all under body seams including rocker panels, fenders, etc. Takes a couple hours but much cheaper than renting a beater car or buying a new truck. There is a rust prevention service that's been mentioned on this site that looks pretty good...kinda pricey though.
If you won't be driving for a few days during the winter, give it a water rinse underneath, around the body seems, inside fenders, etc. No need for soap because water will dissolve the salt and take it off. Truck may still look dirty but removing salt is the key. As long as it's a sunny day, the water will evaporate off...even if the temp is single digits. Helps to have the truck warm and heater on to keep glass clear.
Do not apply anything that forms a film (like paint) under the truck. These products eventually peel and trap salt. No waxy goo inside drains which traps dirt...water displacement (like WD-40) only.
I'd be all over a used pickup truck, but the problem is I'd need seats for kids. Anything with a crew cab is usually out of the question.
Have used fluid film for years.
Near Buffalo, NY. Truck will turn white in the winter with the amount of salt put down. Now they are using chemicals too. Eating vehicles.
People say harsh chemicals are used today that eat cars. That's not really true. The only ingredient that's used is salt. It's sometimes dissolved in water to help it stick to the road instead of bouncing off when applied as rock salt. Often it's sodium chloride because it's cheap. And sometimes it's calcium chloride because it's 50% more effective than sodium chloride. Any salt that dissolves in water will melt ice it's just that the chloride salts are cheap.
The chloride ion is what facilitates the rusting of iron. It will speed iron rusting as long as it's touching the metal. It's easily removed by rinsing with water. It's also very beneficial to coat metal before winter time with something like Krown, fluid film, or other moisture displacing product to stop the flow of electrons from the iron.
