Steering Damper time
Old Aug 27, 2018 | 10:26 AM
BillyBob69's Avatar
BillyBob69
So I replaced my steering damper/stabilizer about 4yrs ago and this past weekend I noticed when I hit a slight bump in the road...I think a pavement seam, I felt the wheel bump to the side a little and had to correct. Didn't take much but noticeable. So in checking it out, it looks blown. Damper juices all over the outside,,,kinda greasy.
So...Shouldnt these last longer? I had the truck for 7yrs prior until I replaced the original. The replacement was a Monroe that came with its own bracket that didnt quite fit so I had to tweak the u-botls a little.
Recommendations on a new one without going high end? I dont run her off road hardly at all. Maybe once a year to go hunting but that is just to tow a small camper and side by side in. Otherwise, she gets driven to work about 3 days a week just to keep the fluids going and maybe pickup a bed load of hay about once a month.
She is currently at just over 337K on the clock.
Thanks all!
Old Aug 27, 2018 | 10:38 AM
mcnance865's Avatar
mcnance865
I would say just grab a bilstein. Probably $50-$70.
Old Aug 27, 2018 | 01:40 PM
BillyBob69's Avatar
BillyBob69
I wish Bilstein was that cheap. The best I can find starts at $91 and goes up from there.
I may just go back to MotorCraft and ignore Monroe as it seems they don't hold up too well.
Old Aug 27, 2018 | 02:43 PM
mcnance865's Avatar
mcnance865
That would be perfectly fine on stock size tires.
Old Aug 27, 2018 | 03:26 PM
BillyBob69's Avatar
BillyBob69
Kinda stock. 285-75 16s
Old Aug 27, 2018 | 04:22 PM
HKusp's Avatar
HKusp
Go with the stock one. I have the Bilstein and I have never liked it running 305's. It's way too tight.
Old Aug 27, 2018 | 05:16 PM
brian42's Avatar
brian42
Veteran: Navy
Stabilizer life varies. It's right out front and takes a beating so environment (road condtions, weather, use) plays a good part in that. I do a lot of off-roading so I burn through them quicker than most I would assume (2-3 years).
Running 285/75-16s on a stock suspension.
I have the stock single stabilizer setup. I usually run a Pro Comp or Rancho stabilizer. I've been happy with both.
Old Aug 27, 2018 | 05:47 PM
Colorado350's Avatar
Colorado350
Regarding a steering stab, buy the cheapest one you can find, it’s only designed to take the jarring aka road feedback out of the steering wheel. Too many people use the steering stab as a bandaid for worn out steering components. You don’t need an expensive stab.
Old Aug 31, 2018 | 03:02 PM
BillyBob69's Avatar
BillyBob69
Thanks for the info all! Just what I needed!
shameless
Aug 5, 2016 06:59 PM
kjf-250
13
May 18, 2012 07:54 AM
Tecman
Feb 8, 2012 11:23 AM
eman588G
Jan 24, 2009 10:05 PM
Sleepies
Mar 15, 2006 08:50 AM
