C6 Lokar shift kit
Old Aug 26, 2018 | 03:59 PM
sinnedspeedshop's Avatar
sinnedspeedshop
C6 Lokar shift kit
I just finished rebuilding my 1975 C6. I picked up a Lokar shift kit and need to install some of the Lokar bracketry prior to installing the C6. The instructions first say to place the C6 into park, but I don't know how to recognize I've placed it into park, or any of the gears for that matter. If someone could give me a crash course on the lever/gear position with the C6 out of the truck?
Old Aug 27, 2018 | 06:31 AM
FuzzFace2's Avatar
FuzzFace2
That in not a shift kit but a shift cable, shift kits go inside the valve body.
As for park put the output yoke in and turn it. If it turns it's not in park.
Park will be at one end or the other of the lever. So move lever all the way in one direction and turn yoke as I said above.
Once you found park the rest if need to find are easy.
Dave - - - -
Old Aug 28, 2018 | 06:24 AM
sinnedspeedshop
Yes, I forget a shift kit is technically for the valve body. But I'm glad you knew what I meant. This is my 1st automatic trans rebuild (as obvious by my armature question). Thanks for the tip, so easy, yet I didn't even think of it!
Old Aug 29, 2018 | 02:57 AM
GaryKip's Avatar
GaryKip
Let us know how it works out.
Old Aug 29, 2018 | 07:03 AM
hivoltj's Avatar
hivoltj
Park is all the way forward
Old Aug 29, 2018 | 09:39 AM
FuzzFace2's Avatar
FuzzFace2
Can the lever be placed uo or down?
If so that will not work on way park the other low gear.
Dave - - - -
Old Sep 5, 2018 | 07:53 PM
JEFFFAFA's Avatar
JEFFFAFA
Dave - - - -
The lever is one way for column shifts and the other for floor shifts. Like in a car.
timothy47129
Jul 19, 2006 11:19 AM
buttnuttn8
May 22, 2002 11:32 AM
rudifisk
Aug 12, 2001 01:39 PM
bigsnag
17
Jul 23, 2001 09:00 AM
