Flathead Head gaskets
Old Aug 26, 2018 | 02:51 PM
Mrln45's Avatar
Mrln45
i got a set of head gaskets, but some of the water passages aren’t the same size or some seem to be missing. I was thinking of trimming the gasket to match the holes. If I leave the gasket as is, I would think it would affect the water flow. Or should I install them as they are?
Gasket and head
Old Aug 26, 2018 | 04:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The design of the holes in the HG's is intended to restrict flow from some areas of the block, and encourage it to go thru other areas. I would not modify the gaskets. Who made the gaskets? Do you have a part number? That appears to be either a Victor Reinz or Best Gasket product?
Old Aug 26, 2018 | 05:10 PM
Mrln45's Avatar
Mrln45
They’re Fel-pro
Old Aug 27, 2018 | 06:18 AM
TitusDH's Avatar
TitusDH
I have the same gaskets, better leave them alone.
If you enlargen the holes, the major part of the coolant will take the shortest way out of the block back to the radiator. Your cylinders in the back may overheat if you insist to try your luck. Just like Ross said.
Old Aug 27, 2018 | 01:48 PM
Mrln45's Avatar
Mrln45
I can see your point. I’ll leave the gaskets the way they are. I’m guessing the gasket designer figured that configuration works better than the original Ford design. I was concerned the constant exposure to the hot coolant might eventually have an effect on the gasket material and break it down to cause it to get into the block. What do y’all think about coating the gaskets with the Permatex Aviation “Form a Gasket” before installing? Or is it better to just install them with nothing on them?
Old Aug 27, 2018 | 03:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If your block and head surfaces are clean and flat, no need for anything. These are the recommendations for Best Graphtite and FelPro head gaskets.
Note that FelPro PermaTorque gaskets are blue; yours are not. Be sure to re-torque your heads after getting it fully warmed up, as many times as needed until the bolts stay at 50 ft-lbs. (Re-torque when cooled back down)
Old Aug 27, 2018 | 03:51 PM
Mrln45's Avatar
Mrln45
[QUOTE=ALBUQ F-1;18162530]If your block and head surfaces are clean and flat, no need for anything. These are the recommendations for Best Graphtite and FelPro head gaskets.
Will do. Thank you
skidoorulz
Mar 31, 2015 03:29 PM
crazy96863
Apr 24, 2013 08:09 PM
Josh88Ford
Aug 11, 2008 11:39 AM
e william
Aug 6, 2005 08:07 PM
woods
Jun 23, 2004 09:47 AM
