Proper head gasket placement?
Old Jun 23, 2004 | 08:51 AM
woods's Avatar
woods
I am installing the heads and noticed that the coolant passages in the head gaskets are different on each end. I looked in the paperwork and it showed all other Ford V-8 motors but not FEs.
All others had the larger passages at the back side of the block and the smaller ones at the front so I figured that would be the same with the FE motor.
I just wanted to confirm this.
Any help would be great.
Thanks
Ken
Old Jun 23, 2004 | 09:07 AM
Putt's Avatar
Putt
The front of the head gasket should not have a water passage. The large water passage goes to the rear, most have front stamped or inked on the gasket surface.
Old Jun 23, 2004 | 09:08 AM
led sled's Avatar
led sled
your making me think ! LOL !! i believe it is the same with the fe motor, but if i'm wrong someone will let you know !
Old Jun 23, 2004 | 09:47 AM
woods's Avatar
woods
The front has a small "maybe" 1/8 inch hole but the gaskets have no markings
They are from a full MR Gasket rebuild set that came from Summit Racing.
Thanks for the responses.
Ken
sdsurf3573
18
May 23, 2016 10:51 AM
Bullitt233
Dec 11, 2015 09:05 AM
palomino73
May 28, 2006 01:19 AM
xfordman
Apr 29, 2005 01:29 AM
captainal
Sep 3, 2003 12:24 PM
