Rear shocks
Old Aug 26, 2018 | 12:57 PM
kenny nunez's Avatar
kenny nunez
Question Rear shocks
Has anyone with a Crown Victoria front clip tried a different set of rear shock absorbers?
Old Aug 27, 2018 | 03:31 AM
GaryKip's Avatar
GaryKip
Are you talking about changing the ride height by using different shocks?
Old Aug 27, 2018 | 07:26 AM
kenny nunez
Since the truck now has the CV clip and is only about 1.5” lower I am trying to get a balance in shock action front to rear.
Old Aug 28, 2018 | 01:08 AM
GaryKip's Avatar
GaryKip
You might be able to contact the tech help section at on of the shock companies. I'm sure they will want to know at least the weight of the truck, and maybe the weights on the front and rear axles. They may want you to measure the amount of travel you have now (or the amount you want to have) too. It never hurts to ask- unless she's married.
Old Aug 28, 2018 | 12:30 PM
kenny nunez
Thanks for the tip, I am going to check on this. The rear travel is close to original and it will remain like that. If I decide to lower it I will re locate the spring mounts about 1” at the most.
Old Aug 30, 2018 | 04:17 PM
JEFFFAFA's Avatar
JEFFFAFA
Seems to me the C/V springs are going to react different than rear leafs. Rather than trying to match front/rear shocks, you might end up trying different rear shocks to make the front/rear springs react the same. Like softer rears to H.D fronts.
alchemist1
Jan 27, 2014 10:12 PM
arrowheadfred
May 29, 2011 06:24 AM
12ozd
Oct 7, 2009 12:08 PM
fergusonicford
May 11, 2009 05:40 PM
dfishrmn88
2004 - 2008 F150
Feb 4, 2008 06:33 PM
