rear shocks
Old May 25, 2011 | 10:10 PM
arrowheadfred's Avatar
arrowheadfred
rear shocks
If you lower your truck do you still use stock shocks ?
Old May 26, 2011 | 05:28 AM
jaye's Avatar
jaye
you may not have enough travel for the stock ones; I would measure the ride height after lowering and then get a shock that are compatible with your measurements and truck weight. After lowering mine I measured and called a Poisies (name close enough) for blistein shocks. They cost about $100 each but they were worth it in ride comfort.
Old May 26, 2011 | 07:58 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Depends somewhat on your shock mounts. My truck was lowered 5-6 inches due to putting the axle above the springs but I was able to use stock 53-55 Ford F-100 rear shocks on it....
Old May 29, 2011 | 12:04 AM
1953f350's Avatar
1953f350
I think you probably need a shorter shock. Anyone here have a picture of the mounts...my truck had no rear shocks from the factory and I am trying to source what pieces I need to add them.
Old May 29, 2011 | 06:24 AM
GreatNorthWoods
Here are my shock mounts and 55 F-100 rear shocks mounted...
Mustangking1
Sep 19, 2013 03:17 PM
cory5517
Jun 2, 2012 10:27 AM
Gwilkrrs
6.4L Power Stroke Diesel
Dec 12, 2010 07:15 PM
BioBurner
Jul 22, 2008 04:09 PM
RedUgly77
16
Jun 10, 2008 10:13 AM
