Lets talk gas tanks...
Old Aug 25, 2018 | 11:33 PM
Unicom's Avatar
Unicom
So i am looking for a bit of info on gas tank swaps for a 1996 reg cab 8ft box truck.
ive done diesel builds up to this point and have an old 96 f150 that im putting together with a 4x4 swap for sentimental reasons.
front tank is shot, anyone tried fitting in a plastic tank from an f250/350 7.3 truck? Is there a difference between the f250 steel tank and f150 tank? I know about the two larger rear tank options just not sure about the front one. I would like a plastic tank if i could and a bit more capacity (this thing is a pig compared to the diesel on fuel)
Old Aug 26, 2018 | 11:22 AM
F350 1990's Avatar
F350 1990
Most of the F-Series tanks interchange................................The older Dodge plastic tanks (I just R&R'd one on a 87 W250) might work also --- physically the older Ram mid-mount plastic tanks look a lot like Ford's. Considerations:
---- lining up the fill
---- internal vs external fuel pumps
---- venting
---- strapping
---- accident "roll over" valves, placement
Old Aug 26, 2018 | 03:28 PM
Brian Ski 44's Avatar
Brian Ski 44
I haven't tried a plastic tank swap. I know there were 2 front tanks, one for the short bed and a longer one for the long bed. I think the long bed used another fuel pump pick up/sending unit. I think with the plastic tanks you may be looking at customizing like posted above.
I wish a plastic tank would work, I think I replaced 3 metal tanks already on mine. In the rust belt here, it is like changing brakes. or brake lines..... I finally figured out the NiCop lines.
Old Aug 30, 2018 | 11:51 PM
Unicom's Avatar
Unicom
Yes im in the same boat, my front tank is just rusted out from all the salt. Im going to see if i can find a plastic tank somewhere for it before i spring for a metal one
Old Aug 31, 2018 | 04:28 AM
EPNCSU2006's Avatar
EPNCSU2006
Jeff's Bronco Graveyard lists plastic tanks, I believe.
Old Aug 31, 2018 | 07:14 AM
Brian Ski 44
I will have to keep an eye on this thread. I got a rust free southern truck. The timer is running on the fuel tanks.
FastTaurusSHO
6.2L V8
92
Mar 23, 2025 11:08 PM
Bigdawg5565
Sep 25, 2015 04:05 PM
iggy2
6.2L V8
Dec 29, 2012 08:19 AM
screwy
6.7L Power Stroke Diesel
25
Apr 20, 2012 04:54 PM
RaulLopez
Jul 13, 2007 07:31 AM
