95 f250 Transmission Fluid Change
I want to change the fluid and filter on my 95 f250 5.8L automatic 4x4, but not sure what type of trans fluid to get or how much. I'm not sure witch tranny is has I'll try to look. Also would the transfer case take gear oil? Or regular automatic transmission fluid, any help is appreciated thank you
Check the data tag in the driver's door opening. Under TR will be a letter code. Most likely it's an E, which is an E4OD.
Here is how to change the fluid in an E4OD. Changing ATF in an E4OD. That procedure needs to be updated, both the E4OD and 4R100 use MERCON V now.
Ryan50hrl
06-10-2002 08:34 AM
