Medium towing HIGH trans temps
2001 Excursion, Stock tune, all stock except 4" exhaust.
Towed a 6x12 two axle enclosed trailer today 60-70 mph on interstate, oil and trans (were) staying around 218F with 86 deg outside all day.
Until... came to a section of road with stop and go traffic and rolling hills with about 30mph max and about crapped my pants when i looked over and saw that the trans had reached 250F and there was no where to go... wall to the left wall to the right...
This went on for a few miles before getting back to speed and set the cruise at 55... it took about 15 or 20 miles to drop back to 230F and stayed there another half hour until i could stop and idle while i picked up some scout parts.
Noticed the fan clutch fully engages when both temps reach about 210 deg range and road speed slows, radiator is 2yrs old, previous owner installed radiator without transmission coolant loop in it.
About 5k ago i flushed the trans with schaeffers, replaced filter and had flow to spec through the fluid/air cooler. No leaves or debris b/t coolers radiator etc...
Will a 6.0 trans cooler upgrade alone get me back to good temperatures or do i need to add in a radiator that includes the trans cooler loop?
Trans is a rebuilt unit with thought to be 60-80k on it.
The trip back home with more downhill and less stopped traffic both oil and trans stayed b/t 215 and 220 same 60-70 mph.
I-20 from augusta ga 20/285/575 to canton these weren't huge hills either.
Thanks for replies.
Thanks for replies.
Stop and go traffic is hell on trans temps with the torque converter unlocked. A 6.0 cooler will dramatically reduce those temps, but there might be something else wrong to get to 250 in those conditions. The highest I’ve ever seen were 220 with the stock cooler, towing 12k in stop and go and 90 degree weather. With the 6.0 cooler, I can’t break 190, even on 100+ degree days.
Its still bright pink on the stick and dabbed on paper towel smells like automotive perfume just like when it went in.
I presume that fluid loop in the radiator can shed a lot of heat into the coolant if you are towing like that with a stock trans cooler.
I run 200-210 in high 90deg weather unloaded. Figured it was from having only an air cooler but never expected to see 250, I seldom travel farther than 10 miles away towing anything.
Dang. If you run that hot unloaded, I start to wonder if your temp sensor is messed up somehow. I have only seen my bone stock 4r100 reach 210 once when I was in my extreme tune going uphill onto interstate and really laying into it. I was unloaded. It jumped from about 185 to 210 and I let off. About 92 degrees outside.
on
I wouldn't be terribly worried about hitting 250, but at that point I would start keeping a close eye on it to make sure it didn't continue rising. You need to get the right radiator, this should keep it under control for most conditions. The couple times I got stuck with a heavy load and slow hilly traffic I dropped into 4low with the hubs unlocked, that took the load off the torque converter. Only problem is that when the traffic opens up you'll have to stop to safely engage high range before you can speed up. I think manually shifting into 2nd will allow the converter to lock up rather than it shifting to 3rd and not locking. Most of the heat is generated in the converter. If the speed is too slow to reach 2nd gear lock-up keep it in 1st and let the engine rev higher, less load on the converter and more air pulled by the fan.
But you also have a cooler in the radiator. That makes all the difference.
