2014 F250 no power windows
Received 3,107 Likes
on
put a new head unit in the 2014 F250XLT for large rear view camera instead of the small one in the mirror.
everything worked fine. 3 hours later i went out to finish the install. rolled the windows down, did sme probing looking for the proper wires to tap into for the rear camera,but decided to not cut or hook up the camera. then put the dash back together.
now the windows will not roll up, rear view camera does not work, and the power mirror extenders do not work either.
all fuses in both in cab and under hood boxes test good with test light.
any ideas what i screwed up? the windows are down, and it is supposed to rain tonight.
The functionality you lost, windows, mirror, rear view camera do not have anything in common that I am aware about. I would start by removing the items installed or at least unscrew them and check for pinched wires.
The proper place to pick up the video feed from the rear view camera is in the right hand kick panel area. I know a 2011 radio is different from the 2014 setup but 4DTech made me a cable to connect to the radio and the plug in the kick panel area to not only show the camera in the mirror but also the radio. They might have these cables made up or maybe can make you one.
on
the thing is, nothing was installed.
i probed the wires on the passenger side going up behind the grab handle, i thing it was green with blue stripe had power for a few seconds, then no power and the rear view mirror camera went dark. when i went to close the windows after that they would not work. after testing all fuses i tried everything else and found the power extending tow mirrors were the only other thing that did not work.
tjc transport
Electrical Systems/Wiring
09-28-2018 05:08 PM
tjc transport
1999 to 2016 Super Duty
02-01-2017 05:30 AM
