How to lower windows with remote
Old Aug 24, 2018 | 10:51 PM
Richard Saenz's Avatar
Richard Saenz
How do you lower your windows with the remote. I have a ‘17 Lariat with an Ultimate Package.
Old Aug 24, 2018 | 10:55 PM
PentaPop's Avatar
PentaPop
I have no idea but every time my 1 yr old plays with the fob I go outside to find the windows down so it must be doable!
Old Aug 24, 2018 | 11:03 PM
CPal's Avatar
CPal
If I'm not mistaken I believe with vehicle off and locked you just press and hold the unlock button on keyfob. Only works on front drivers/pass window tho if I remember correct. Tried it a few months ago when someone mentioned how to do it never seen much need to use tho so haven't since.
Old Aug 24, 2018 | 11:10 PM
D3thM3tal's Avatar
D3thM3tal
Unlock and then unlock again and hold.
It is the reverse to close them all - lock and then lock and hold.
Old Aug 24, 2018 | 11:37 PM
ford390gashog's Avatar
ford390gashog
I thought global window close was disabled from factory and had to be enabled?
Old Aug 24, 2018 | 11:54 PM
CPal's Avatar
CPal
They will go down without forescan, you will need forescan if you wish to be able to make them go back up via remote.
Old Aug 25, 2018 | 06:57 AM
Richard Saenz
Thanks guys. This is perfect for these Texas 100+ degree days. Any extra way to get the hot air out before I get in makes a huge difference.
Old Aug 25, 2018 | 07:11 AM
D3thM3tal's Avatar
D3thM3tal
Huh, trucks must be different then as my wife's Fusion did both out of the box.
Old Aug 25, 2018 | 04:22 PM
Steelcity's Avatar
Steelcity
I have a 2017 Lariat with the ultimate package and this feature does not seem to work for me.
Old Aug 25, 2018 | 04:51 PM
D3thM3tal's Avatar
D3thM3tal
Time for Forscan..
Old Aug 25, 2018 | 04:57 PM
Raptor Rob's Avatar
Raptor Rob
My 17 Platinum will go down, but as stated above will not go up. However My Wife's 18 Expedition goes up and down. I didn't know this was an option until I read this thread and wandered outside to have a Looksie.
Old Aug 26, 2018 | 06:35 AM
Gazoo2010's Avatar
Gazoo2010
I found the option in the advanced settings on the instrument cluster menu. I checked the box for auto open and auto close and works grreat.
~S
Old Aug 26, 2018 | 07:40 AM
GABAR's Avatar
GABAR
Very odd that you can roll them down via the remote but not up.
Old Aug 26, 2018 | 08:22 AM
n1ncz's Avatar
n1ncz
On my 2017 Platinum -Roll Down was delivered from factory but had to use Forscan for Roll Up
Old Aug 26, 2018 | 10:17 AM
bushpilot's Avatar
bushpilot
Global windows down is ENABLE by default
Global windows UP is DISABLED from the factory
You need (free) ForScan software (runs on windows) and a bluetooth OBDII dongle to write changed to the truck to enable things like global windows UP.
To learn more about FORSCAN software go to this THREAD
To see what things are possible (changes) with the software look at this spreadsheet
All of this is DIY and pretty easy (looks intimidating at 1st but its not.
There is a forum members that are willing to help - check some of these "forscan for hire threads"
Below is the forscan information to enable global windows up.
