Need help with engine ID VIN decode please
Old Aug 24, 2018 | 01:01 PM
fatheroftwo's Avatar
fatheroftwo
The van has a small block V-8 (302 OR 351W), that is very hard to get at since it is in a van.
VIN: E14HHX24849
Do these engines take the same cap plugs and rotor? I am getting conflicting info from rock auto.
Thank you in advance.
Old Aug 25, 2018 | 08:09 PM
baddad457's Avatar
baddad457
Yes same cap and rotor and plugs for both (depending on what heads) . Get the brass terminal ones. (cap and rotor) The aluminum ones are crap. I use Autolite or Motorcraft copper plugs
Old Aug 25, 2018 | 08:25 PM
fatheroftwo
Thank you, nice line up of cars you have there. All of my nice ones are gone.
Old Aug 25, 2018 | 08:52 PM
baddad457's Avatar
baddad457
Don't have em all now, but thanks ! The Comet's the only one still around
Old Aug 25, 2018 | 09:36 PM
fatheroftwo
That's plenty, you can only drive one at a time! lol
Old Aug 28, 2018 | 03:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The van has a small block V-8 (351W), that is very hard to get at since it is in a van.
VIN: E14HHX24849
E14 = E150.
H = 351W
H = Lorain OH Assembly Plant.
X24849 = 1975.
Cap & rotor changed in 1977. No 302's in 1975/78's.
Old Aug 28, 2018 | 04:06 PM
baddad457's Avatar
baddad457
E14 = E150.
H = 351W
X24849 = 1975.
It has the small cap and rotor then. These can be replaced with the larger, later (post type) cap and rotor, all you need is the cap adapter, which sometimes is included in a cap/rotor package. I'm running this type on my 77 Comet's 331.
Old Aug 28, 2018 | 04:08 PM
fatheroftwo
Thank you very much sir, that is exactly what I was looking for. The decoder I found using google showed it to be a 390.
I knew that was not correct, although it would have doubled the value! I am very fond of the FE engine.
My dream goal for this van would be to put a 460 with a 5 speed. It has a three on the tree.
I am not sure if it is even possible to put a 5 speed shifter in the van.
Old Aug 28, 2018 | 05:50 PM
fordman75's Avatar
fordman75
They were available with the light duty Mazda 5spd's in the late 80's. In your van, you may have to trim a floor cross member and modify the dog house.
tromano32
33
Apr 30, 2021 06:25 AM
xtrakr
Jul 29, 2018 09:02 AM
Angel Tollens
General Automotive Discussion
Jan 3, 2018 09:08 AM
SwampyBull
Aug 4, 2012 01:54 PM
spartan986
Jan 17, 2011 08:44 AM
