Fuel on dipstick
Old Aug 23, 2018 | 08:51 PM
northforder's Avatar
northforder
Fuel on dipstick
Fuel on my dipstick. 95 f150 xlt 5.8H. New injectors + fuel pump assembly. Just changed the oil and filter and plugs . Approximately 168,000 miles.
Old Aug 23, 2018 | 08:58 PM
Conanski's Avatar
Conanski
Does fuel pressure drop immediately after the engine is shut down? If so one or more injectors is stuck open, this is really common with the newer style injectors.
Old Aug 24, 2018 | 05:36 AM
northforder
Didn't start. Cylinders flooded, then the gas went into the oil pan. Been doing that for awhile now. Came out of a shop and drove it for about 75 miles. Wouldn't start. Called the shop. Back and forth with them for a few weeks. Suddenly said its under warranty .Expressed my concern about bringing it back to them and ending up with the same
results. Plus them taking more of my money wasn't going to happen.
A week later more BS. Drove it back to my place, about 4 blocks away. Did the work I put in mentioned at the beginning of this thread. Hasn't started since.
Old Aug 24, 2018 | 07:14 AM
rla2005's Avatar
rla2005
Check the fuel pressure regulator. Pull off the vacuum hose then inspect the port for signs of fuel. Common failure mode is the internal diaphragm ruptures which allows raw fuel to be sucked into the intake.
Old Aug 24, 2018 | 08:12 AM
subford's Avatar
subford
Was it running OK before the work they did?
Why did you have this work done by them?
Old Aug 24, 2018 | 09:00 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Drove it back to my place, about 4 blocks away. Did the work I put in mentioned at the beginning of this thread. .
How much fuel do you guess is in the oil? I would have been concerned about engine damage from the diluted oil and not driven the truck.
Old Aug 24, 2018 | 12:00 PM
Primetime1's Avatar
Primetime1
Agree with this. That much fuel can take the bearings and crank out. I'd change that oil ASAP
wrdabney
6.4L Power Stroke Diesel
May 30, 2016 07:46 AM
Saber123316
Nov 8, 2007 07:04 AM
The Padre
Jul 27, 2007 04:39 PM
Diamond Jim
Nov 12, 2006 06:49 PM
55-willys
Mar 20, 2005 07:54 PM
