New injectors needed, fuel in crankcase
Dropped my '08 6.4 with 85,000 miles on it off this morning at Ford dealership because it was rough idling and the reduced engine power warning and engine light were on. They said one/some of the injectors were sticking and there was 3 gallons of fuel in the crankcase. They quoted me about $3,400 to replace all injectors. I have an easy care warranty on it so hopefully they will cover it. Is there any more damage that could have occurred from the fuel in the crankcase that I should try to get them to fix while it's in?
Edit: Just heard back from Ford. Easy Care doesn't consider this part of the power train warranty...what? How is this not power train?
Because when they crack the fuel rails they are probably going to find metal and that means fuel contamination.
Bad fuel isn't Ford's fault. And with how sensitive fuel systems are on modern diesels they are generally excluded from warranty. If they find no sign of contamination then that's different however and if I were you at that point I would start pushing for it to be covered.
If they do find metal, rust, or water and you have proof of proper filter maintenance using only Ford filters then you can go after a fuel station provided you keep a fuel log and receipts. And ofc consistently fill up at the same station. This is usually a very long process, insurance will go test the fuel from where you filled up and if they find contamination then you will get help with repair cost.
But the long story short is multiple bad injectors means water has probably found its way into the hp fuel system. And your $3400 repair might turn into an $8000 repair if this is the case... And it is in no way Ford's fault.
