Transmission question 2006 e350
Old Aug 23, 2018 | 03:39 PM
merrilllangs's Avatar
merrilllangs
i have 2006 e350 v10 203,000 miles. Last week or so transmission giving trouble when van is warm on restarts. Start van after sits couple hours and it’s fine drive for miles and no problems. Stop at gas station and restart and it shifts a bit rough and no overdrive. Any ideas?
Old Aug 23, 2018 | 06:01 PM
wirelessengineer's Avatar
wirelessengineer
The basics, first. Fluid level? When was the last time it was serviced?
Heat problems might be a solenoid.
Old Aug 23, 2018 | 08:09 PM
ford390gashog's Avatar
ford390gashog
203k on a 4r100 that's impressive, but check the fluid level. However it's most likely got a blown seal on the apply servo or a worn out housing and will need a rebuild.
Old Aug 23, 2018 | 08:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The last year of the 4R100 was 2004. This is a 5R110W TorqShift. Also, the 4R100 only has one servo, and it is only used when the shifter is in the 2 position. The 5R110W does not have any servos, so that's not the problem. Almost certainly the problem is lazy, sticking solenoid(s.) Often new fluid and some time will fix this.
Old Aug 24, 2018 | 06:51 PM
Im50fast's Avatar
Im50fast
Don’t forget Mark a year ago when mine had a similar issue. I replaced the TFT and it was immediately solved.
My symptoms were:
-wouldn't shift beyond 3rd even on the highway
-would slam into reverse or drive unbelievably hard.
Very easy driveway fix. Drain fluid and pull pan and then it’s about 10seconds to fix it.
Make sure tyou use the correct fluid to refill. Mine requires Mercon SP and it took about 10quarts.
Old Aug 26, 2018 | 06:58 PM
Czar308's Avatar
Czar308
Trailering
Thanks @merrilllangs for the timely thread. My 06 E350 with a 5R110 behind a 6.0 Powerstroke developed issues last week, right at the end of a family vacation. (Dodged a bullet there.)
Started to feel surging on the freeway as if it were downshifting incorrectly or lockup on the torque converter was uncoordinated. OVERDRIVE light on shifter was flashing. Got the van home and when shifted in to reverse to back onto my driveway, it slammed in and stalled the motor. Sounds closer to symptoms described by @Im50fast. (TFT referenced was the temp sensor for the trans?)
Pulled codes and came up with P0742 and P0743. These both came back as torque converter issues. Would this warrant replacement of solenoids? Or is this is service and time resolved issue? Thanks
Old Aug 26, 2018 | 07:07 PM
Im50fast's Avatar
Im50fast
I’m no expert here.
I went to local ford stealer and they said to replace the TFT and its wiring harness. Something like $1200 or so. they said maybe the TFT alone will fix it, but they wouldn’t take the chance of skipping the harness.
I did it at home in my driveway and it’s been fixed ever since.
Old Aug 26, 2018 | 09:14 PM
Mark Kovalsky
Those indicate an electrical short to ground in the torque converter clutch solenoid circuit. It might be the solenoid, but it usually is in the wiring to the solenoid. Some electrical diagnosis is called for before replacing any parts.
Old Aug 26, 2018 | 11:21 PM
Czar308's Avatar
Czar308
Trailering
Thanks for the quick response @Im50fast and @Mark Kovalsky.
Almost wishing that there was a solenoid replacement. I know how to turn a wrench, electrical diagnostics not my strongest suit. Mark, from your experience, what are the chances they are the circuits that sit inside the pan? They seem very robust to me. My big fear is that I will have to track down this short somewhere in the confines of the Econoline engine compartment. Really tight quarters in there.
Old Aug 27, 2018 | 04:43 AM
Im50fast's Avatar
Im50fast
Minor thread hijack
So what transmission is in my 2005 E250 4.6L?
Old Aug 27, 2018 | 06:32 PM
Mark Kovalsky
It's usually the wiring outside the transmission. It may not be the most elegant solution, but you could just run a replacement wire instead of finding the bad spot.
I believe that would be a 4R70W.
Old Aug 27, 2018 | 09:58 PM
Czar308's Avatar
Czar308
Trailering
Talking
[QUOTE=Mark Kovalsky;18162805]It's usually the wiring outside the transmission. It may not be the most elegant solution, but you could just run a replacement wire instead of finding the bad spot.
I try not be hack about repairs, but i may have to resort to this. Thanks again.
Old Sep 5, 2018 | 02:56 PM
Czar308's Avatar
Czar308
Trailering
Mark Kovalsky, follow up question. Finally got a chance to turn the van around on the driveway and my problem is no longer there. Shifted normally into reverse and drive, but did not get a chance to freeway it to cycle torque converter solenoid for lockup. Just about to pull rear harness and bench test. Question is would the P0742 and P0743 codes come up on startup with a self test or is this something that requires a road test?
Old Sep 5, 2018 | 04:03 PM
Mark Kovalsky
If I remember correctly it has to attempt to lock the converter to set those codes, so it would take a road test.
Old Dec 16, 2023 | 09:02 AM
diamondx's Avatar
diamondx
Trailering
LOW mileage trans issue
2006 E350 5.4L .... only 25k miles ! seller states does not move --trans issues. Is this most likely something simple or ?
Mileage IS correct.
