I got a 1995 ford f-350 with a 351W, runs rough when in drive or reverse it spits and sputters then dies. I replaced the throttle position sensor, mass air flow sensor, and the engine coolant temperature sensor it also idles a little high, what could it be?
You have a '95 5.8L F350 with MAF? Is it obdi or obdii (possibly California emissions?)?
Start with the basics:
0. Check codes first.
1. Have you done basic maintenance? Plugs, cap, rotor, fuel and air filters, PCV valve, clean MAF.
2. What is the fuel pressure: with vacuum to the regulator, without vacuum to the regulator, and most importantly what is the pressure when it is stumbling?
3. What is engine vacuum at idle? The high idle may indicate a vacuum leak.
Why did you replace the parts you replaced already? Throwing parts at a truck without diagnosing is a good way to introduce more variables to the problem you're trying to solve.. new doesn't always mean good.
3. What is the engine vacuum at idle? The high idle may indicate a vacuum leak.
checked codes replaced the sensors because came up in the codes. The reason why it has a MAF instead of a MAP is that my truck got burnt from the heater caught on fire so I had to replace the wire harness and the computer. I got a wire harness and computer and pretty much every electrical sensor off of a 92' f-250 if that gives you any clue
Not really since that truck definitely would not have been MAF from the factory. Was your truck MAF originally? Did you replace ALL of the EFI wiring after the fire as in everything back to the PCM or just the engine portion?
Not really since that truck definitely would not have been MAF from the factory. Was your truck MAF originally? Did you replace ALL of the EFI wirings after the fire as in everything back to the PCM or just the engine portion?
I replace it all, and no my truck was not originally MAF
OK, can you post some pics of your engine bay and the wiring connector or connectors at the PCM. To get MAF into a '92 there would have to be an overlay harness which would mean 2 nested connectors at the PCM, does your truck have that?
Are there any codes right now?
Do you know the catch code for the PCM?
OK I don't see a piggyback connector there so maybe the additional wiring is hardwired in. Are you still getting codes for things that have been replaced? If so post up the code numbers.
KOEO Test: 126,556,637
KOER Test: 998,126
I know 126 is MAP sensor but the wire harness doesn't have the electrical plug for it, it only has the plug for the MAF
So it appears you somehow got a MAF wiring harness and an SD PCM, can you remove the PCM and post up the catch code or some pics of it to verify, there should be a label on it with some numbers.
If I changed the wire harness to a map will that solve the problem?
