Stumble at Idle
Old Aug 23, 2018 | 12:28 PM
steinernm's Avatar
steinernm
Stumble at Idle
2005 F-250 6.0L with 67,000 miles. I have an intermittent stumble at idle that popped up a few weeks ago. It only does this at idle and it only happens maybe once a week. The RPMs used to surge a little bit at idle (would only happen once a month) until it got warmed up but now the RPMs are dropping like you can see in the video below. Where should I start? Is this classic stiction or is it a sensor (ICP)? I am looking into FICM repair because it looks weak but I think the FICM might not be related? Thank you!
Old Aug 23, 2018 | 01:03 PM
Brotherbillstruck's Avatar
Brotherbillstruck
Checking for any trouble codes stored that have not popped the check engine light is where I would start.
Old Aug 23, 2018 | 01:06 PM
steinernm's Avatar
steinernm
Thanks. I forgot to mention that there are no trouble codes.
Old Aug 23, 2018 | 02:39 PM
jswartz84's Avatar
jswartz84
What is your ICP at hot idle?
Old Aug 23, 2018 | 04:47 PM
steinernm's Avatar
steinernm
ICP @ hot idle: 580 psi
Old Aug 23, 2018 | 04:57 PM
jswartz84's Avatar
jswartz84
Ok, your IPR should be around 22% at 580psi . Could be looking at a high pressure oil leak.
Old Aug 23, 2018 | 04:59 PM
steinernm's Avatar
steinernm
It is 22% at 580 psi
Old Aug 23, 2018 | 05:01 PM
jswartz84's Avatar
jswartz84
That doesnt look bad, I was going off the IPR % in the video.
Have you tried unplugging the ICP sensor and reseating the connection?
Old Aug 23, 2018 | 05:07 PM
steinernm's Avatar
steinernm
I have not tried that. Do I unplug while it is running? I think the 2005 is on the passenger side valve cover?
It acts up real infrequently. For instance, it did not do it on today’s morning commute to work and hasn’t done it all week. And then when I ran an errand for lunch is when it happened. Then no issues on the commute back home after work.
Old Aug 23, 2018 | 05:13 PM
jswartz84's Avatar
jswartz84
No, unplug it while the key is off. Mine did this years ago, it started out maybe once a week, then got more frequent. I pulled over and reseatted the ICP connector and the problem went away.
Old Aug 23, 2018 | 05:17 PM
jswartz84's Avatar
jswartz84
Oh and you are correct, the ICP is located on the passenger side valve cover toward the front.
Old Aug 23, 2018 | 05:18 PM
FiznUKa's Avatar
FiznUKa
You have an injector dropping out.
Old Aug 23, 2018 | 05:30 PM
steinernm's Avatar
steinernm
I will try unplugging the ICP sensor and re-seating it.
If that doesn’t fix it, then the next likely cause is injector?
Old Aug 23, 2018 | 05:43 PM
FL SuperDuty's Avatar
FL SuperDuty
Watch ICP press while it is stumbling and see if the reading is changing.
Mine does the same thing. I either have a bad ICP or a bad connection/pigtail/wire that’s intermittent
Old Aug 23, 2018 | 06:42 PM
FiznUKa's Avatar
FiznUKa
Does this stumble almost feel like the engines going to quit? Or are you watching the RPM gauge fluctuate a little up and down? When I had an injector going out it was like the engine was going to stop.
