Sponsored by: Real Truck
Odd electrical problem
Old Aug 23, 2018 | 11:38 AM
Motohead911's Avatar
Motohead911
Ok, I have this odd problem, the other day I had to lay on the horn for someone trying to cut me off. Anyways the horn stayed on and I had to pull the fuse to get it to quit.
Also unrelated I think I was driving with the cruise on and when I hit an expansion joint on the freeway the cruise turned off. I reset it and it happened again at the nest joint.
On last thing I am getting a DTC for the key on the ignition. I also have DTCS for the cruise ground faults.
Anyways, the question is where should I look to fix these problems, I am thinking somewhere in the steering column?
Justin Doe
43
Jun 19, 2015 07:43 PM
Rediranch_too
Electrical Systems/Wiring
May 4, 2011 09:34 PM
jayc3169
Mar 20, 2011 09:25 AM
scotncinci
1997 - 2003 F150
Feb 8, 2008 10:51 AM
CJay
Oct 11, 2007 10:28 PM
