Horn and Cruise Control not working!
Having a problem with my horn and cruise. The climate controls and radio controls all work fine. When I noticed the problem, I checked the fuse panel and found that the fuse had blown. When I changed the fuse, it instantly blew. The horn sounded for a half a sec before the fused popped. I went through this 3 more times until I ran out of 15s. Then I put a 25 in and the horn blew constantly until I pulled it out. Tried one more 15 and it blew out again. What could be the problem?
I have same concern on my 00. I diag the horn circuit first (easiest) & tracked it to the dg/or pin 6 at the cruise servo. If I jumper that wire to pin 10, ground. The horn circuit works fine. The cruise will not lite the green lite on dash or even do a self diag? I have already tried a clockspring just cause. It has had the brake switch update, but the switch is leaking? Has anyone had a bad servo causing similar concerns?
tlinetrader
08-15-2016 12:33 PM
Plowboy34
03-24-2016 11:55 AM
