U-Joints and FLex couplings.
Old Aug 22, 2018 | 04:12 AM
User 71024's Avatar
User 71024
Just throwing this out there, I am considering tossing the integrated 4-spd/transfer case in the '79 shorty for a divorsed transfer and a 3.03 long ratio 4-spd I have. to save length I've been considering a flex joint instead of the intermediate shaft from the highboy. Does anyone have any input as to style of flex joint or any negatives about the idea?
Old Aug 22, 2018 | 08:22 PM
mark a.'s Avatar
mark a.
Are you talking about a Joy coupler or what ?
Old Aug 23, 2018 | 05:24 AM
User 71024's Avatar
User 71024
something on that line, I contacted Lovejoy, and explained what I was after and they said they do not make anything for "automotive use". Not sure if it was an honest answer from a "tech", or just a generic answer from a flunky that tried to look it up on his computer screen.
I'm just trying to eliminate the short shaft, to make the whole unit shorter. I figure the less rear shaft angle the better. I know from experience it isn't a good idea to use a standard U-joint in a straight line because it it can't rotate at an angle it wont lubricate the needles, so they rust and come apart. I guess I could do it with a single u-joint and just grease it frequently, but I was hoping for something that needed less attention.
Old Aug 23, 2018 | 09:23 PM
mark a.'s Avatar
mark a.
It is going to be hard to find or make up anything to match. Either way with a short bed you are going to have to get a steep angle cv and those aren't cheep.
Old Aug 24, 2018 | 06:34 AM
User 71024's Avatar
User 71024
The way it sits now it's only about a foot longer than the stock setup. I'm trying to research the toploader to see if I can get a shorter tail shaft, but sofar nothing is showing up. If I get stuck using a short intermediate shaft I may be able to lower the transfer case a bit to lessen that angle.
urbex
Jan 19, 2018 11:36 AM
5.4L to Freedom
Jan 30, 2010 07:58 PM
cowboyty
13
Feb 3, 2007 07:17 AM
dunsterj
May 21, 2004 09:51 AM
jphillip
1978 - 1996 Big Bronco
Apr 2, 2002 10:40 AM
