EFI 460 Differences?
Old Aug 21, 2018 | 01:45 PM
arcticcatwill's Avatar
arcticcatwill
Exclamation EFI 460 Differences?
I understand that in 93 ford put different heads with bigger intake valves making more power but was there any other differences? Pistons?
I have a 1990 f250 (115k) I picked up for $500 just for the motor to put it in my 94 F350 CC. I didn't know about the differences at that time.
Can I put the newer heads on the older short block without and problems? I found a 96 motor for $170 or $70 for the heads only at the local pull & save. No clue on condition or miles at this point.
Old Aug 22, 2018 | 09:43 AM
Primetime1's Avatar
Primetime1
Yes you can put the newer heads on the older short block.
Old Aug 22, 2018 | 11:21 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Here is a link to a thread where I posted another link. Follow that link and read the thread at 460ford.com.
https://www.ford-trucks.com/forums/1...h-headers.html
Parts swapping isn't engine building. Shopping in a catalog isn't engine building. Parts don't make power, systems make power.
You can make more rpms, more cylinder pressure or more cubic inches. Or you throw your time and money away. Stick with proven builds, don't throw your money away.
You are going to burn more fuel to make more power. It cost you now and it keeps costing you.
Old Aug 22, 2018 | 11:56 AM
arcticcatwill
Its not that I'm trying to make more power as much as I'm trying not to loose power. My motor is using coolant and burns enough oil to be annoying. I do plan on doing a EFI friendly comp cam to help out some and headers. Headers mainly to ditch the factory garbage. But thanks for the info on interchange for parts.
-Will
Old Aug 22, 2018 | 02:34 PM
HardScrabble
New valve guide seals have fixed bad oil consumption issues with the 460 but I think you are lucky if it does.
Speed Density friendly cam is about vacuum at idle. The engine builders over at the 460ford website have gotten good results using marine cams that ramp up faster. That is the difference with roller cams, they ramp up faster. They are pushing the flat tappets to their limit with the more aggressive ramps. Read over there some, it's addictive.
If you spend some time and money you can zero deck the 460, cam it, do some porting and make it what it should have been.
150ford
Sep 21, 2016 10:38 PM
Plumdog2015
Nov 15, 2013 10:43 PM
YoungFordAddict66
Dec 21, 2008 11:15 PM
460dragger
Aug 23, 2007 12:03 PM
crack
Dec 12, 2005 08:34 PM
