AOD trans specs
Old Aug 21, 2018 | 08:55 AM
Truckman8719's Avatar
Truckman8719
AOD trans specs
92 f150 5.0 XLT 2wd AOD trans
Im trying to figure out how long is the tail housing weither its 10.25 or 11.25. When I measure from the back side of the plate housing out towards the driveaxle (at the metal ring housing end im getting something like 9.75). When I meassure from the back side of the plate housing towards the drive axle (at the end of the rubber boot that comes out the transmission im getting 11.25.
Anyone know the true tail piece length for this truck?
Also I found a u pull it parts but can't tell me the transmission. Its a 94 Ford ecoline rwd 5.0. What transmission typically would that have in it?
Old Aug 21, 2018 | 09:16 AM
Truckman8719
Also are the extension housings interchangable? Such as if i found a 10.25 would I be able to put an 11.25 ext housing on it?
Old Aug 21, 2018 | 10:43 AM
rla2005's Avatar
rla2005
A recent thread on the same topic: https://www.ford-trucks.com/forums/1...ur-trucks.html
Old Aug 21, 2018 | 11:08 AM
Truckman8719
Same **** I ran into. There is no straight forward answer.
Old Aug 21, 2018 | 03:12 PM
Conanski's Avatar
Conanski
Could have been one of 3 or even 4 but most likely to be an E4OD or 4R70w. Check the trans code on the drivers door pillar, U=4R70w, E=E4OD, T=AOD.
lio45
Mar 16, 2018 07:17 PM
Montync
Apr 13, 2016 09:24 PM
kjfassoc
Jan 21, 2006 12:35 PM
rdy
Jul 20, 2004 08:46 PM
