Hello all! I have a smaller bumper pull toy hauler (GVW 9100#) pulling with my 2015 F250 PSD 4X4. Here in California, we do mostly desert riding, with 1 trip per year to Glamis sand dunes.
Currently my truck has Toyo Open Country AT2 tires on it. After 41K miles, these things are toast. I don't like the idea of spending a 1000 bones every couple of years or so. Looking for other ideas, considering highway A/S for more longevity. Do A/T tires really make a difference if your not doing mud? In the sand dunes I had to deflate these Toyo's to around 20 psi to get un-stuck even with 4 wheel drive. In the desert, its to and from the campsites on roads varying from hard pack to a little sandy.
Anyone else doing light off road with highway tires and not really regretting it?
Lt's for the F250. I bought the A/T's because I thought they were needed for any off road, and they looked cool.
A quick look at their website shows the Toyo's in my size (LT275/70R18) have a load capacity of 3640 lbs. Searching around, highway all season tires from Firestone, Bridgestone, and Michelin have the exact same load capacity. I am just disappointed in the Toyo's longevity,,,,or lack thereof.
My current truck ('17 F250 FX4) still has the OE Wranglers but it and all of my previous trucks have lived almost exclusively on the highway. I really only go "off road" when looking to park my car hauler, and that's usually grass, or when my wife and I go camping with our 26' travel trailer. Previous trucks always had A/S tires (previous trucks were always 2wd) and I never had any problems getting anywhere. The Van did remarkably well actually.
That said, when out on the Drive-On beaches in St. Augustine, the trucks I see getting stuck are the ones with big lugged mud tires. This is because, in sand, the big lugs do a great job of digging holes. The All Season tires, if you are careful with the throttle and steering, don't dig holes. Or maybe its just idiots showing off
Either way, when its time to replace the OE tires on my '17 Super Duty, its getting All Seasons for highway use.
I do mostly hiway but have done 30% off road and have been caught in the snow zones a ton. Ever since being sideways on I80 coming off the Lincoln summit coming down off the Lincoln summit into Laramie, I run ATs and stay clear of the AS. If I was still down in SOCAL still I would probably run the AS due to cost and longevity. You can definitely get the right load range and capacity in the AS.
That being said I live where there’s 35 miles of beach I can drive when I want and see others with the big Mudders getting buried to their axles and laugh when they call my buddy George to pull em out (see Hill Autobody and Towing on U-Tube https://m.youtube.com/user/HILLAUTOBODY ). He’s got some good ones there. He records most every tow he does even his brothers when they get stuck.
I’ve learned a little more weight and a light touch on the throttle keeps me going even in the dry loose stuff. When the rear end starts to shudder and bounce time to back off. I also have onboard air so I can drop the pressure to give me a little more contact area then just air it up coming off the sand.
I have no idea what tires work best in sand but A/T tires are much, much better on greasy wet dirt driveways and roads (where there's little gravel). They're also much better on rain slick grass compared to all seasons. Nothing short of super swampers are much good in soupy mud or soft, rain soaked clay.
I was running Toyo RT tires. I only go about 238K out of mine. I ended up getting money back on the milage warranty. You might want to look into it to help with replacements.
Boaterguy,
238k??? That's a lot to ask out of any tire🤣🤣🤣
The toyo's are a 60k tire, and just to clarify, I do replace mine when they are low, but not to the wear bars yet. Prior to these, I was used to getting 60-70k out of a set of bridgestone highways and still had some meat left.
I run Micheline defender LTX M/S on my 2011 F250 CCB 4X4 pulling a 12,000lb bumper pull toy hauler and mostly go to Oceano Dunes with some desert. I do have to air down the truck and trailer but these tires work great and should go 60,000 miles, my last ones did. They don't look as cool as some of the big lug tires though.
