Broken multi switch
Old Aug 20, 2018 | 04:13 AM
BostonJoe's Avatar
BostonJoe
Broken multi switch
so I snapped the multi switch off of my 11 Ford F-150. It looks like it’s been repaired before. Can anyone tell me what the multi switch connects to. I’m hoping it’s a part on the column that’s replaceable and not the whole steering column. Any help would be appreciated. Thanks in advance
Old Aug 20, 2018 | 04:34 AM
seville009's Avatar
seville009
Assuming you’re talking about the turn signsl/wiper arm, it’s a simple replacement of just the switch. The end of the switch inside the column is just basically a circuit board that screws in. Very simple to do. Replaced mine 4 or 5 years ago. Bunch of YouTube videos out there
Old Aug 21, 2018 | 05:16 AM
BostonJoe's Avatar
BostonJoe
Broken multi switch
Yes it is a very easy fix if it’s just the multi switch. My problem is more than just the multi-switch. What the multi-switch connect to inside the steering column is broken. I am just looking to find out the name of what the multi-switch gets attached to
Old Aug 21, 2018 | 07:50 AM
seville009's Avatar
seville009
I see.....little more complicated.
I don’t know the answer. Can you get in close enough to msybe see a part number you could google?
When i replaced my mfs, i snapped off one of two screw parts that holds it on. I could still connect the circuit board though and could one screw back in. It’s worked fine since then; hasn’t come loose.
Is the circuit board connection broken or just the plastic screw points? If it’s the screw points, maybe put some glue in, let it dry, and drill a tiny hole in it for the screws.
Old Aug 21, 2018 | 05:28 PM
Siberexpress's Avatar
Siberexpress
If you look at Fords online parts they have a part listed for it Steering Housing
bryansshort
Electrical Systems/Wiring
Jul 2, 2015 08:58 AM
Charles77f150
Nov 24, 2014 06:44 PM
Matt1966
Aug 17, 2013 03:50 PM
gl0116
Jan 21, 2009 06:16 PM
lt281
Nov 14, 2008 04:33 PM
